Sponsored by: Real Truck
Remove Decal
Old Oct 16, 2015 | 11:50 AM
JackOHearts's Avatar
JackOHearts
Remove Decal
Hello to the Group,
I would like to remove the 4X4 decal from the rear fenders of my new F 250.
Is there a way to do this and not screw up the paint ?
thx
dkf's Avatar
dkf
Heat it up with a hair dryer and peel it off slowly.
Old Oct 16, 2015 | 12:07 PM
phillips91's Avatar
phillips91
If you use a scraper, make sure it is plastic. Don't use anything like paint thinner that will dissolve the adhesive as it will mess up the paint. Heat, patience and a soft edged scraper are your best options.
rlanicek's Avatar
rlanicek
I was curious about this too. Is it under clearcoat or on top? Has anyone tried to remove it?
Old Oct 16, 2015 | 01:01 PM
dkf's Avatar
dkf
It is a sticker over the clearcoat. I had a booboo with my truck shortly after I bought it and the bedside got repainted. Sticker just stuck on when the paint was dry.
Old Oct 16, 2015 | 01:04 PM
Chuck's First Ford's Avatar
Chuck's First Ford
if you can feel a sharp edge.. no clear coat on decal
or use a small magnifying glass.. see if edge is clean or filled in.
electric heat gun.. and go slow... no scrappers. finger nails
if its been ON for several years.. Forget it.. paint under it will be a different shade of color.
Old Oct 16, 2015 | 03:00 PM
bryyce62's Avatar
bryyce62
It comes right off. I used a real dull exacto blade to get it started. Peeled off in 3-4 pcs.
Old Oct 16, 2015 | 03:57 PM
CR3999!'s Avatar
CR3999!
I just use my nails and peeled the corner up and pulled. I did that the first day I got the truck. There was a little residue left, just get some WD-40 spray some on a rag and it comes right off.
Old Oct 16, 2015 | 08:17 PM
Topglock's Avatar
Topglock
On factory paint it will be on top. You can start the removal with a single edged razor blade, but be very careful. Once it's started, just peel it off. Any adhesive that remains can be removed with mineral spirits, nothing stronger. As a graphics shop that specializes in custom automotive graphics and wraps, I've been doing this for over 20 years. Just take your time and you'll have no problems..
Old Oct 17, 2015 | 10:09 AM
msgtord's Avatar
msgtord
My truck had been sitting in the sun for an hour when I just used my fingernails to get it started and then pilled it off. Easy.
Old Oct 17, 2015 | 11:01 AM
DJRAAL's Avatar
DJRAAL
Originally Posted by JackOHearts
Hello to the Group,
thx
Be careful when using heat to remove the decal, to much and you can damage the paint underneath. All you have to do is use a low setting and work slowly. best thing to do is park it in the sun on a hot day and let'er heat up then work slowly to peal it off. Should work just fine, a little glue let over will come of with WD 40.
Old Oct 17, 2015 | 11:10 AM
hodge5's Avatar
hodge5
I heated mine with a hair dryer, used a plastic scraper to get it started, then cleaned the residue off with WD-40. Worked like a charm.
Mine had been on for 13 years, and the paint had not faded around it. Truck must have been inside a lot.
Old Oct 17, 2015 | 12:36 PM
Stan B's Avatar
Stan B
4x4 sticker removel
I removed mine on a hot day they came right off.
Old Oct 17, 2015 | 08:14 PM
Tom A's Avatar
Tom A
Sounds like they'll peel right off, but for the stubborn ones, you can buy a decal eraser wheel that goes in a drill and will take them right off. And it won't hurt the paint at all.
Old Oct 17, 2015 | 10:59 PM
JackOHearts
Thanks for all the input. Gonna try to peel it off Monday.
Got to thinking, I have only had it for a month and bought it new (2015 model), but I am sure that it sat at the dealer for a number of months....
Oh well, I just think it will look a lot better w/o the 4X4.....
2015 F-250 SB CC Gassser
