Making AOD fit FE
Old Feb 22, 2006 | 03:09 PM
averagef250's Avatar
averagef250
Making AOD fit FE
I am a pro-manual tranny guy and don't own anything with an auto, but I've come into posession of a good 88 AOD and I have several Fe-C-6 cores laying about. For a fun project, I was going to chop the FE bellhousing off a C-6, CNC machine the AOD case and the C-6 bell and TIG them together. It was a slow day today so I played around with the tape measure and calipers and the bellhousings will line up well for welding, BUT all the FE flexplates I have laying around have 6 bolt holes and an AOD converter has 4 studs. Anybody know if there was ever a 4 hole FE or 385 series flexplate that will bolt to a small block AOD converter? I am not very well versed in auto tranny technicals. If it works, the hybrid AOD will be for sale.
Dustin
Old Feb 22, 2006 | 03:29 PM
rusty70f100's Avatar
rusty70f100
I'm pretty sure they all have the 6 bolt holes.
I think by far the best option would just be an adapter.
http://www.transmissionadapters.com/ford_fe.htm
Old Feb 22, 2006 | 03:36 PM
ford390gashog's Avatar
ford390gashog
700.00 is not a bad price. but why build a nice 427 and use a orange can of death?
Old Feb 22, 2006 | 03:56 PM
rusty70f100
I was kind of wondering about that too. He's just probably uninformed.
Old Feb 22, 2006 | 04:09 PM
averagef250
I'm an idiot! All FE flexplates have 4 bolt holes. I have stacks of flywheels and flexplates and thought that my FE flexplate pile was the biggest. The biggest stack turned out to be chevy flexplates. I was sctratching my head trying to make a 350 flexplate fit an AOD converter. The FE flexplate fits the AOD converter, but there isn't enough room for the flexplate to crankshaft bolt heads. There's about an 1/8" difference in the offset of the FE flexplates to small block flexplates and those bolt heads just won't clear. I don't think this project will work after finding this out. I really don't like adapter plates much though. I started machining 6BT cummins to Ford adapter plates after a good friend that owns a diesel shop had alignment problems using other's plates. Some places making these plates just don't watch what they're sending out the door.
Dustin
travisd
33
May 8, 2018 10:10 AM
Wagonboy
Jan 31, 2016 03:02 AM
Jeff Ranger
Apr 19, 2015 09:26 AM
TireDood
Mar 25, 2015 10:03 AM
niteowl
22
Aug 12, 2005 10:03 PM
