8" and 40s
Feb 23, 2006 | 09:38 PM
Bear, how about front/rear bumper height, and front headlight height with the new tires.
Cali is also concerned with a ground to frame height (lowest part of the frame I assume?)
Truck looks gret BTW...do you wash it yourself?
Feb 23, 2006 | 10:22 PM
LOL...yeah I wash it myself...
Headlight is 56" to center.
Not sure about bumper height laws...so I'm just guessing at where it needs to be measured to..
Front bumper 47" to top portion center
Rear bumper 43" right above license plate
Let me know if you need measurements to different points on the bumper.
Feb 24, 2006 | 09:04 AM
I think the bottom of the bumper.
Is that truck legal in Texas? I think we have a center of headlight limit of 54.
Feb 24, 2006 | 12:36 PM
Ok...I can get you some new measurements when I get home. You are correct 54" is the limit to the center of the headlights.
Feb 24, 2006 | 01:51 PM
Ok I finally got to measure mine and I'm at 17 1/2 as well with a 6 1/2 inch lift.
Feb 24, 2006 | 01:55 PM
cali is 54, but i THOUGHT that was to the bottom of the headlamps........fwiw.
im a little guy, im only 45" to the bottom of the headlamps.
the malls around here do not have that large of speedbumps for me to crawl, texas must have some serious moundage!
Feb 24, 2006 | 03:14 PM
Yep if you guys are at 17.5 then you got about 10" out of it given the average is about 7.5"
Matt... nope its to the center of the headlight
Feb 24, 2006 | 04:37 PM
Wow if I got 10 out of that lift thats unbelievable
Feb 24, 2006 | 05:19 PM
ok, JUST measured, again. been quite a while...
axle housing to bottom of frame rail 14" exactly.
ground, to TOP of headlamp was 45", not to bottom (knew that didnt sound right).
17.5" from a 6.5" lift is huge.
Feb 24, 2006 | 05:58 PM
Yeah it is.... Matts measurements sound correct for a 6" lift on a PSD
Gassers will sit taller than a PSD with the same lift due to the weight of the engine....
JaBerryhill...That's huge for a 6.5 on a gasser....that's why you gotta be careful when you say 38 on a 6.5 is fine....it's all about the frame to axle measurement because each truck can be a little different...and a whole lot different if it's a gasser.
Feb 24, 2006 | 07:18 PM
How about the ground to frame measurements? I gotta get my truck lifted before they make these laws more strict...
Bear, any law enforcement problems?
