V6 4.0 Engine Compression Questions
Old Feb 21, 2006 | 09:02 PM
rio002's Avatar
rio002
Lightbulb V6 4.0 Engine Compression Questions
I was wondering what the compression on a V6 4.0 engine should read.
Any help is appreciated Thanks!
Old Feb 22, 2006 | 07:57 AM
srercrcr's Avatar
srercrcr
I can't answer your question for sure, but Ford has historically used a "relative" method, meaning they should be clustered relative to each other. For instance, for the 4.9 they say if one cylinder has 150, the minimum allowable for any other would be 113.
Personally, I feel that's a stretch.
Old Feb 22, 2006 | 09:12 AM
grease monkey's Avatar
grease monkey
Thats right on the money. The cylinder that has the lowest rating should not be lower 75% of the highest rated cylinder.
Old Feb 22, 2006 | 10:39 PM
savagefan's Avatar
savagefan
Those specs. are mostly warranty CYA. 10-15% max variation or problems will be apparent.
Old Feb 22, 2006 | 11:54 PM
rio002's Avatar
rio002
Thanks all, sounds like the engine we picked up is right in line on the compression.
fexplorer04
Oct 15, 2012 10:11 AM
rdfenn3
Jul 13, 2011 07:05 PM
Theunknown
1997 - 2003 F150
May 13, 2011 09:16 PM
PM PAINTING
Apr 8, 2011 10:23 PM
sjrogers
1983 - 2012 Ranger & B-Series
Mar 2, 2007 11:44 AM
