Underhood sticker missing
Old Feb 20, 2006 | 07:55 PM
green76ford's Avatar
green76ford
Does anybody know what the timing specifications are for a 1976 Ford F-250? I need the specifications for a 390 ci 4bbl 4 wheel drive engine. The underhood sticker on my truck is long gone. Thanks.
Old Feb 20, 2006 | 08:06 PM
Mil1ion's Avatar
Mil1ion
Ah Timing on a 390, ?
The FE forum will have those specs as that's where the engine questions are best asked.
We were just discussing this in another Active thread.
I'll see if I can find it.
I think the setting is 15*BTDC
Welcome to the site
To help your time on FTE to be favourable,may I suggest reading this thread
https://www.ford-trucks.com/forums/s...d.php?t=102632
Old Feb 21, 2006 | 02:44 AM
tomcasino's Avatar
tomcasino
I have a tune-up spec. manual for older vehicles.
'76 Ford 390 4V (Exc. Calif.)
Plug gap .045
Manual trans. timing 14* BTDC @ 650 RPM
Auto trans. timing 16* BTDC @ 650 RPM
This should get you close.
Old Feb 21, 2006 | 02:52 AM
ford390gashog's Avatar
ford390gashog
well most of us FE guys don't run them with more than 12 BTDC and no more than 40 total advance. the sticker is probably long gone because that 390 was not stock so it was swapped over . it had a 360 stock (may still be a 360 unless you stroke check it)
Old Feb 21, 2006 | 10:38 PM
Mil1ion's Avatar
Mil1ion
The specs I posted are original Ford specs for the truck.
No swap job.... if it's original.
Old Feb 21, 2006 | 11:53 PM
ford390gashog
dennis it had to of been swapped at one time or another. the 4x4 trucks only came with 360 2bbl not a 390 with a 4bbl.
Old Feb 22, 2006 | 11:28 AM
Mil1ion's Avatar
Mil1ion
I missed the 4x4 part
So much for intensive reading
Mustangking1
Jan 25, 2015 09:59 AM
1saxman
2004 - 2008 F150
Mar 1, 2007 10:39 AM
