I noticed that when I shift into reverse, it will feel like the driveline has to make up for slack... Hard to explain, but its like something is worn out and has a bit of play.
it is only noticable when you first shift into reverse. once it goes through slack, the driveline feels tight as normal.
In drive (all forward gears) there is no *driveline slack* even when stop and go commuting e.i. driving somewhere parking, restarting, putting it into drive and taking off etc..
But when I want to stick it in reverse it feels kinda like the driveshaft has about 1/10th play.
Is this normal? or is this a symptom of something on its way out.. the truck drives fine, seems to shift gears fine, cant detect any tranny slipping etc..
when it gets REALLY cold out, I start the truck and let it warm up for a few mins (these fords seem to take forever to get warm in dead winter)..
Once I take off it feels like the truck is sluggish. the power feels like its there, it seems like there is a bit of drivetrain resistance.. once warmed right up it feels snappier..
My first guess would be the wheel bearings might be a bit dry and in need of a replacement or repacking.. also possibly the rearend might not have had a fluid swap in a long time..
The wheel bearings are a must service, what do you guys think?
still having fun working out all the little kinks from my recent truck purchase. One good thing is this truck is about 10,000 times easier to work on than my previous (and newer) pontiac grand am
Could it be a situation with worn old U-joints loading up when going into reverse?
Whats the factory driveshaft made from? the driveshaft appears to be REALLY clean, like someone may have put an aluminum shaft on the truck at some point.
My 94 did it both going into drive and reverse. When I had the tranny rebuilt, it did not do it as much. It felt just you as described, like the slack in the driveline was being taken up.
My u-joints were fine. We have a few 94 f-150 at work, some do it some don't.
I believe your tranny is a 4RW70. Post your tranny code.
I had the tranny re-built because of slow shifts and slipping, going into overdrive.
If your trans code is U then you have an AODE or 4R70W. If it is a 302 with automatic then it is bound to be this transmission. From what I understand this transmission is the same as the one in the cars: crown vics mustangs etc, but it has a different ratio. I have never seen an F150 with a 302 and an E40D. I have seen what you have described on several trucks. My truck does it sometimes. I don't think it is anything to worry about. Servicing the trans as well as the other things you mentioned couldn't hurt anything and might help.
Mr. Galizien, have you found your tranny code yet? My '91 with an E4OD does exactly as you describe and has done so ever since I acquired the truck - about four years ago. I have serviced the diff., transmission and changed out the u-joints and haven't noticed any significant change in the behaviour of the way the tranny goes into reverse. Yes, it does seem like there is some slack there and I believe that Quicklook2 will give us an answer to solve the problem - Right Quicklook2?
My 94 automatic makes a rumbling noise when I come up on a slight hill. This will happen at 40mph or 70 mph. Likeit is having trouble down shifting. Almost sounds like it does when you are in a manual and you fail to shift down when stopping. Other than that the Truck runs fine. Kind of pricy driving it with 12-18 MPG. But I really like my truck.
