Hydro Boost Leaking
Old Feb 20, 2006 | 08:36 AM
crazyd1980's Avatar
crazyd1980
Hydro Boost Leaking
Hey ya'll
My '91 F-450 w/ 7.3 International has been leaking hydro fluid from up where the brake pedal goes through the firewall. It seems to be coming from the back of the hydroboost unit. The brakes also have no pedal, you have to push the thing to the floorboards to get it to stop. Do you have to replace the whole Hydro unit or can you replace seals. Would fixing the leak fix the pedal.
Old Feb 20, 2006 | 09:20 AM
PLC7.3's Avatar
PLC7.3
What is leaking is the Input seal, I have not found any repair scheme for that. I would guess it requires replacement............check with a brake specialist in your area.
Note.....To remove... pump the pedal several times to discharge accumulator. Remove the master cylinder from HB unit and prop it up out of the way.
DO NOT pump the booster with master cylinder removed...........
Old Feb 20, 2006 | 10:16 AM
crazyd1980's Avatar
crazyd1980
The HB leaks at the rear where the shaft from the brake pedel goes into the unit
Old Mar 1, 2015 | 06:00 PM
7.3TurboDiesel's Avatar
7.3TurboDiesel
hydro boost
My hydro boost is leaking on the inside of my firewall. I just bought a new hydro boost, power steering pump and power steering box. High pressure hoses are new, as well as a few low pressure. I was cleaning my truck when I noticed it was leaking. Any advice on what to do? I have pressure, but there are times when the brakes grab and hold and other times I have no pressure at all. Please help.
Old Mar 2, 2015 | 01:26 AM
ifrythings's Avatar
ifrythings
If you just replaced the unit and it's leaking, return it....
Other wise you can get seal kits http://www.ebay.com/itm/Hydro-boost-repair-rebuild-kit-NEW-complete-2771004-/331234467794?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d1f1cdfd2&vxp=mtr
Be warned though, to remove the push rod from the front of the hydro unit is a pain in the a$$ as it's a crimpped connection and not really a user service able item, it can be done though.
Old Mar 2, 2015 | 02:36 AM
7.3TurboDiesel
boost leak
So would create the problem of the brakes locking up, being able to push the pedal to the floor? Mainly having pressure sometimes and sometimes not?
1fast93stang
Large Truck
39
Aug 18, 2024 01:49 PM
Kuhns71
18
Aug 22, 2016 12:22 AM
martinleeo
Mar 21, 2015 09:16 AM
Oscarsf3506.0
Nov 20, 2012 06:12 PM
JHoffman93
Dec 5, 2009 11:55 PM
