starter problem?
Old Feb 18, 2006 | 08:05 PM
killer4x4's Avatar
killer4x4
starter problem?
Went to start my 84 6.9 this morning about 0 degrees with the wind chill and wasnt plugged in cause the cord shorted out by the looks of it the other day.Turned the key let the glow blugs do there work light went off then i cranked it over but while cranking the glow plug light went on again and i heard a wierd sound. then tried again and it went from cranking over to nothing just stopped and it gives out one click.
Did the starter burn up?
I have noticed a smell coming from it in the past times while doing work on it like return lines and whut not but still did not crank it for more than 10 sec. saw that black wire on the starter was hot and smoking but that was like 2 weeks ago . Guess she dosnt like the cold.
Old Feb 18, 2006 | 08:14 PM
trader rob's Avatar
trader rob
sounds like corrosion at terminal ends, bad ground. tr
Old Feb 18, 2006 | 08:40 PM
killer4x4's Avatar
killer4x4
the positive cable is new no corrosion is visible grounds are decent. havnt had any starting problems since the block heater broke.
Old Feb 18, 2006 | 08:41 PM
Pigeon's Avatar
Pigeon
if it clicks every time I would check the starter seloniod on the passanger side fenderwel. I dont recomend this but you could use a screwdriver to touch both terimnals and if your starter turns you know it is the selinoid, which is a common problem. it only costs about 12 dollars.
Old Feb 18, 2006 | 08:44 PM
killer4x4's Avatar
killer4x4
Tried that this morning. I just gives One click not abounch of clicks just one.
Old Feb 18, 2006 | 11:30 PM
PLC7.3's Avatar
PLC7.3
Certainly sounds like the solenoid on the starter is toast..... how old is the starter. A Mitsubishi from Azone would be advised.
Old Feb 19, 2006 | 02:01 AM
jboard's Avatar
jboard
My truck did the same thing a few months ago same symptoms.I Got a starter from NAPA and WOW it was great $150.00-$160.00. Spins it over real fast, make sure you have a good set of batteries too. Check your solenoids first though.
Jeremy
Royson12
49
Mar 15, 2014 04:50 PM
Idiomaticman
Apr 27, 2010 06:57 PM
ghunt
Dec 23, 2008 10:10 AM
timcos
Sep 10, 2008 10:57 PM
ihopemytruckisok
26
Dec 28, 2004 07:08 AM
