Running on the warm side
Old Feb 17, 2006 | 03:58 PM
bodian's Avatar
bodian
My 79 F-350 460, Auto. come to find out only has a two row radiator, I was wondering what it came stock with? I am going to replace it soon, should I spend the bucks on a four row or would three be sufficiant. I will be doing some towing next summer, also has anyone dealt with radiator.com? they are about half the price of the local shop.
Old Feb 17, 2006 | 06:04 PM
Torque1st's Avatar
Torque1st
Posting Legend
Welcome to FTE!
A three row will work well as long as everything else is OK. A 4 row will not cool double the cooling over a two row. Make sure you have a good OEM style fan shroud and a standard OEM type thermostatic fan clutch. Some of the HD thermostatic fan clutches are real noisy since they always seem to stay partly engaged.
Old Feb 17, 2006 | 08:35 PM
Mil1ion's Avatar
Mil1ion
Do you have a 5 blade or a 7 blade fan ?
Old Feb 17, 2006 | 08:46 PM
bodian's Avatar
bodian
Its a seven Mil1ion, New engine,water pump, fan, everything but the radiator.
Old Feb 17, 2006 | 09:13 PM
Mil1ion's Avatar
Mil1ion
I doubt you'll need anything more than a 3 core.
There is barely enough room to R & R the fan set up as it is with a 2 core rad
nevermind going to a 4 core.
I have a 429 with the original 2 core rad and It never overheats.
Old Feb 17, 2006 | 09:35 PM
bodian's Avatar
bodian
Thanks for the reply Dennis, maybe the guage is inacurate, but that is what I was wanting to know if the 2 core was stock, I think your right, 3 core should do the job as far as pulling a travel trailer.
Dave
Old Feb 18, 2006 | 11:59 AM
Mil1ion's Avatar
Mil1ion
Yep that info above relates to pulling a holiday trailer as well as shown in my gallery.
Run the engine up to the temp (with rad cap off) where you see the gauge go high and then put a candy thermometer in the coolant to verify temp.
Old Feb 18, 2006 | 02:32 PM
User 71024's Avatar
User 71024
Bodian, where do you live? Million is in Canada.
Old Feb 18, 2006 | 02:48 PM
bodian's Avatar
bodian
fifty miles north of Cut bank Montana, Del Bonita U.S.- Canada Border. Mil1ion is strait north of me.
Old Feb 18, 2006 | 03:38 PM
User 71024's Avatar
User 71024
well then you can take his advise, i've made the mistake a couple of times thinking the guy I was talking to lived up north and found out they were in Texas where it gets a tad warmer
Old Feb 18, 2006 | 04:21 PM
Bdox's Avatar
Bdox
Also see my post under "heating cooling ventilation and A/C" labled 'more is better?'
Old Feb 18, 2006 | 05:26 PM
Mil1ion's Avatar
Mil1ion
I should have asked if the engine heats up at idle or driving down the highway and the conditions when it does.
In the middle of the summer Texas Temps are what 90*F
It gets to the same temp where Bodian is .
It's not uncommon to hit 87-90*F in Medicine Hat in July/August where I have driven.
My Travelling includes Osoyoos,Oliver,Pentiction,Kelowna, BC where it can be 95*F or 35*C on a regular basis.
I just don't ever have an over-heating problem in any of my vehicles.
Old Feb 18, 2006 | 05:49 PM
bodian's Avatar
bodian
It doesnt seem to make any difference Dennis at idle or highway 3/4 to hot side of guage.the same situation with the engine I just pulled out, When Ford down here put the rebuilt in they suggested a 3 or 4 row replacement. I havent got my candy thermometer out yet, snow and been 10-20 below zero here
Old Feb 18, 2006 | 05:55 PM
ford390gashog's Avatar
ford390gashog
well the stock gauge means nothing. they really can't tell you much. if its at 3/4 and just stays there then you should be fine. but i would install some aftermarket gauges with water temp and oil pressure to give you a good idea of whats going on.
Old Feb 18, 2006 | 06:03 PM
Mil1ion's Avatar
Mil1ion
My gauge hangs around the M on normal.
Ford gauges aren't really dependable.
That's why I suggest to users to actually confirm it with a candy thermometer before they do Anything .....especially buy parts.
