Offroad & 4x4
welding spiders
Old Feb 17, 2006 | 03:54 PM
chrono4's Avatar
chrono4
welding spiders
if i pull the carriers out of my donor axles and weld them up, as long as i put the spacers back in the same spots, will i have to get them resettup? thanks guys.
Old Feb 17, 2006 | 06:11 PM
fords_forlife's Avatar
fords_forlife
as far as i have been told as long as the carrier is going back in the same axle you shouldn't have any problems but if the axles are unknown condition it might be a good idea to have em checked with the added stress of welded spiders.
FORDS_FORLIFE
Old Feb 17, 2006 | 08:10 PM
fishmanndotcom's Avatar
fishmanndotcom
as long as you dont loosen the bolts holdin the ring gear on the carrier!
no.... but lay everything out. and i mean exactly! remember which side was up, out, over, under, etc. it DOES make a difference
-cutts-
Old Feb 17, 2006 | 10:19 PM
chrono4's Avatar
chrono4
ok, i guess ill try doing it without setup. if i screw it up, then ill just hawk up the dough. thanks guys.
kevin316
Aug 20, 2012 02:13 PM
JOHN2001
25
Oct 17, 2011 05:59 AM
MAKO314
Sep 12, 2007 05:33 AM
GreatNorthWoods
Garage & Workshop
40
Mar 6, 2004 10:35 PM
q_ball
Mar 26, 2001 09:07 PM
