Siphoning Gas
Old May 7, 2001 | 11:16 AM
jarch's Avatar
jarch
Siphoning Gas
From the Aux tank to the Main (front) tank on my '78 F-250 4X4 Is driving me crazy. When I fill up the rear tank, the next morning, it says half full, while the main tank says completely full (when it was half full before). Furthermore, gas going to the engine will only draw out of the rear tank 'till it's empty, and then will draw out of the front tank - no matter which tank is selected with the selector switch.
Also, the main tank leaks a lot of gas out of the filling nozzle on warm days. Is there some kind of negative pressure developing in the main tank or what? What could be causing this and how do I fix it?
Could it also be a bad selector valve as well?
Thanks.
Old May 7, 2001 | 10:40 PM
weldman's Avatar
weldman
Siphoning Gas
Try the fuel regulator that is mounted in front of the rear tank. $50 I think. Should control the siphoning problem! I had to replace mine because my rear tank would't let out fuel!
https://www.ford-trucks.com/dcforum/User_files/3ae0a7e34062b4ad.jpg https://www.ford-trucks.com/dcforum/User_files/3ae0a7b33fe32dbb.jpg
1978 F250 4x4 - 351M
Don't crush them, restore them!
Old May 8, 2001 | 08:39 AM
jarch's Avatar
jarch
Siphoning Gas
Thanks weldman.
Now, what exactly is a fuel regulator so I know what to look for. Is it on the fuel line? Is this different than the solenoid selector switch?
Thanks,
Jeff
Old May 8, 2001 | 12:38 PM
weldman's Avatar
weldman
Siphoning Gas
See http://members.home.net/mattjibb/buildup9.html
Third picture down!
Old May 8, 2001 | 02:21 PM
tetraruby's Avatar
tetraruby
Siphoning Gas
I had the same leakage problem on my '79 F100. The filler vent tube (the smaller one) had become dried out from repeated fuel swelling and no longer could seal well. It was a bear but I replaced it and the main filler tube after dropping the tank. Pressure shouldn't build - there's supposed to be a valve on top of the tank to release gas vapors into the Evap system.
Old May 8, 2001 | 03:13 PM
4byford's Avatar
4byford
Siphoning Gas
Old May 8, 2001 | 03:55 PM
jarch's Avatar
jarch
Siphoning Gas
Weldman,
Thanks. We're talking about the same thing. I will see if I can fix the problem when I can take the beast out of service for a while.
Old May 8, 2001 | 04:05 PM
monckywrench's Avatar
monckywrench
Siphoning Gas
The fuel switching valve is a simple solenoid valve that is easy to replace. Take it as a sample to a good auto parts store and they should be able to get a suitable substitute.
86'F-150
84
Jan 22, 2013 10:33 PM
Apollo1
Nov 20, 2008 08:15 AM
Don S.
Apr 24, 2008 10:58 AM
Redleg319
Mar 17, 2004 08:52 AM
wolf189
16
Dec 16, 2001 10:33 PM
