headers
Old Feb 18, 2006 | 12:53 AM
Bdox's Avatar
Bdox
Originally Posted by ivanribic
L&L uses some really weird nickle coating or something to that effect. It's not quite shiney like chrome, looks more like a silver spray paint but it doesn't come off and doesn't rust. If you ceramic coat them it voids the warranty. If I had any other headers I'd get them ceramic coated. I'm going to just built my own set next time around.
Sound like a proprietary coating called Jet Hot. It works.
Old Feb 18, 2006 | 12:57 AM
Torque1st's Avatar
Torque1st
Posting Legend
Jet Hot is just one brand of ceramic coating.
Old Feb 18, 2006 | 01:17 AM
ivanribic's Avatar
ivanribic
Here's what the L&L's look like, fenderwell style:
Old Feb 18, 2006 | 11:26 AM
Torque1st's Avatar
Torque1st
Posting Legend
Looks just like my ceramic coated headers...
Old Feb 18, 2006 | 12:07 PM
78fordranger's Avatar
78fordranger
SO are the fender well exit a better Idea then the inframe? I mean I want headers but like space too is there any problems by haveing fender well exit header?
Old Feb 18, 2006 | 09:27 PM
ivanribic's Avatar
ivanribic
The only issue some guys run into with fenderwell exit headers is their tires will rub them and reduce turning radius. This really has to do with the configuration of the truck in terms of tire size and lift (if any). I don't have any issues with them rubbing because of my lift. I know there are some guys running them that had to turn out their steering stops a bit to keep the tire from touching at full turn. If you keep the plastic fender liner you'd probably need to trim it back so it doesn't melt. That's about it though. I like not having any of that junk between the frame rails. It makes work on the truck 10X easier than it was before.
CanadianBigBlue460
13
Aug 1, 2010 10:23 PM
Dolby4040
May 10, 2006 01:29 PM
FlowmasterMan
Exhaust Systems
Dec 17, 2001 10:37 PM
FlowmasterMan
Nov 28, 2001 09:17 AM
cubster
1983 - 2012 Ranger & B-Series
Oct 23, 2001 07:32 PM
