T 18
Old Feb 16, 2006 | 10:36 PM
78fordranger's Avatar
78fordranger
Yeah my Dad bought the truck new in 78 and the motor beens swap from a 351M to a 390 which is in it now far as I know the tranny hasnt been changed I am pretty sure it cast iron or something because when I put a clutch in I seem to think the top was as beafy as the rest of the case but I geuss looks could be decieving becase it could be think alumimum
Old Feb 16, 2006 | 11:03 PM
78fordranger
Okay guys to be honest about it doesnt look like alumimuim but I could be wrong but I did get a set of #s off the top plate D4T3-AAA2 any Ideas on this?
Old Feb 17, 2006 | 07:35 AM
Thomasm67's Avatar
Thomasm67
Cast iron should look more brownish or rusty campared to the aluminum top of a 435.
Old Feb 17, 2006 | 07:44 AM
bmc69's Avatar
bmc69
Ford used a sprinkling of both T-18s and N-435s in both 2wd and 4wd trucks, 1/2 throuhg 1-ton, all through the '70s and well in to the 80's. I have plenty of both..there are no hard and fast rules..seems pretty random, even withing the same model and year of truck.
Another very easy way to tell them apart is simply to look at how the shifter is retained in the tranny top cover (meaning all you have to do is unscrew the floor boot and look)
The T-18 shifter retainer cup is on the outside of the tower and is threaded on. The NP-435 retainer cup engages pins on the inside of the tower..push and 1/8-turn to lock/unlock... (and is a hatefull thing to get both on or off).
Old Feb 17, 2006 | 08:29 AM
Thomasm67's Avatar
Thomasm67
Tell me about it last year mine popped off and i think it was due to not being put back on correctly needless to say my shifter came out at the wrong moment when i was trail running and was in 1st gear had to drive a couple miles back to my camp site in first.
Old Feb 17, 2006 | 09:42 AM
78fordranger
YEah mine doesnt look rusty just kinda black from oil and the shifter has a cap on the outside and if I remember right I had to unscrew it to get it out.
Old Feb 17, 2006 | 10:06 AM
bmc69's Avatar
bmc69
If the shifter retainer screws off the tower it is indeed a BW T-18.
Old Feb 17, 2006 | 10:51 AM
78fordranger
seems to be a tough transmission it been though alot of hot rodding thaks eveyone for the help
Old Feb 18, 2006 | 08:28 AM
lasthighboy's Avatar
lasthighboy
im pretty sure my 79 f-350 4x4 has a t-18. 1st gear doesnt seem as low as the np435 in my 77 highboy. anybody know what the actual 1st gear ratios for these 2 trans were? also, could it possibly be a t-19 or what were these used in?
Old Feb 18, 2006 | 09:06 AM
bmc69's Avatar
bmc69
working off memory here (bad idea on a hung-over Sat morning..), the T-18 is 6.32:1 and the NP-435 6.79:1...or something very close to those numbers.
Old Feb 18, 2006 | 10:14 AM
bbf150's Avatar
bbf150
anyone sell new or rebuilt t-18's?
Old Feb 18, 2006 | 10:34 AM
78fordranger
theres a post on here that shows how to totaly rebuild a T 18 with pictures cant remember where its at. I think it was in the tranny forum
Old Feb 18, 2006 | 11:15 AM
  #28
75crewcab's Avatar
75crewcab
The shift pattern for the t-18 trans reverse shifts foward or toward the dash. The np-435 reverse shifts back or toward the seat.
Old Feb 18, 2006 | 11:24 AM
  #29
FordPickup460's Avatar
FordPickup460
Pretty close. The 435 is 6.69:1. Some Dodge NP435's had a 4.56:1 1st gear.
Old Feb 18, 2006 | 11:31 AM
  #30
bmc69's Avatar
bmc69
The T-18s come/came with both of the reverse shift patterns that you identified..and most of the ones used in the later 70s and on have the same 'reverse-back' shift pattern as the 435 does.
