Sponsored by: Real Truck
upfitter switches
Old Feb 16, 2006 | 03:43 PM
Blackwaterforge's Avatar
Blackwaterforge
upfitter switches
2005 F-450.
upfitter switches don't work?
I am assuming they are the 4 wires left side of engine compartment.
Old Feb 16, 2006 | 06:29 PM
Deluxe05's Avatar
Deluxe05
That sounds accurate. One of the write-ups states:
Originally Posted by Richard L. Ray
You can add additional accessories to your Super Duty easily, as Ford has provided four 14 gauge wires in the wiring harness as a "pass-through" the firewall. There is no need to drill holes through the firewall to install additional wiring. These circuits can be used for lights, a relay for an electric winch, or any other use you can think of. The wires terminate inside the cab behind the fuse panel near the parking brake. The wiring is contained in a bundle marked "CUSTOMER WIRING" The wires terminate outside of the cab in the engine compartment, near the hood hinge on the driver's side in the vicinity of the brake master cylinder.
That write-up can be found here:
http://members.***.net/richardray/High_Idle.html
Old Feb 16, 2006 | 06:30 PM
Deluxe05's Avatar
Deluxe05
This might also prove useful:
https://www.fleet.ford.com/truckbbas/non-html/Q117.pdf
Old Feb 16, 2006 | 06:55 PM
69cj's Avatar
69cj
The wires you are referring too are spare pass through wires to the cab area. The upfitter switch wires are on the driver side above the emergency brake pedal in the cab.
Old Feb 16, 2006 | 08:37 PM
Slipperyrock's Avatar
Slipperyrock
Did you hook them up?
Old Feb 16, 2006 | 09:51 PM
Antacus's Avatar
Antacus
When I first connected my upfitter I did not tighten down the ground. Did not allow anything to work until I fixed that.
Old Feb 17, 2006 | 07:41 AM
Blackwaterforge
Hooking them up may help a lot! Thanks
When I bought truck I didn't know I would have to finish it.
Old Feb 17, 2006 | 08:08 AM
DavidB's Avatar
DavidB
You are not having to "finish it". You are simply making use of one of the features provided so that you would not have to come here and ask how to get wires through the firewall, etc.
Appreciate the work that Ford already did for you!
Old Feb 17, 2006 | 01:14 PM
skyman_43's Avatar
skyman_43
upfitter switches.....
The orange upfitter wires that go to your switches are located behind the inside fuse panel under the dash. You drop down the fuse panel and the 4 orange wires are labeled for the switches 1,2,3,4.
Old Feb 17, 2006 | 11:07 PM
stratto4's Avatar
stratto4
This is great information! I have the upfitter switches and thought I was still going to have to drill through firewall.
mlbmd
Apr 2, 2009 09:55 PM
Froglips
Sep 14, 2008 08:23 PM
woody367
Feb 20, 2008 11:32 AM
captkrunch
Jun 23, 2006 07:02 AM
14u2nv
Jan 18, 2005 06:52 AM
