Sponsored by: Auxito
lubing chassis
Old Feb 16, 2006 | 02:55 PM
amaezing's Avatar
amaezing
lubing chassis
Dumb question! Do you lube the chassis/driveline on a 1999 F250LD? I have not found any zerks on the universal joint or ball joints.
Old Feb 16, 2006 | 03:17 PM
KingRanchMan02's Avatar
KingRanchMan02
Lubing the chassis is always a good idea. Having no zerks, just means that you will have to use a needle to get the grease into the joints. Have fun!
Old Feb 16, 2006 | 06:02 PM
steve(ill)'s Avatar
steve(ill)
FORD saved $.49 by leaving 6 grease zerks off a $30,000. truck. When they wear out, you can get replacement ball joints and drive shaft universals that have grease zerks. Then grease them every other time you change the oil. You can try the needles in the mean time, it might help.
FordTruckChuck
1997 - 2003 F150
Sep 19, 2015 07:05 PM
mfp4073
1983 - 2012 Ranger & B-Series
Aug 8, 2015 08:48 AM
gene daniels
Aug 10, 2014 10:53 AM
Eddie
Feb 24, 2000 04:21 AM
