Seatbelt light and Ding-Dong
Twag, Tried the procedure below and got all of the correct confirmations, but the bell still goes off when I'm not buckled in and turn the key to on. I don't understand what the procedure did, if anything. I don't drive anywhere without my belt on but I usually don't buckle before starting either. The bell at start up is annoying. I did do the door open, key in, no chime procedure and love it.
"Here is the procedure for the beltminder disable.
You can Deactivate the Belt Minder two ways. First, you can deactivate it temporarily for your current "run cycle", that is after you have started your car and it's still running. Second, you completely deactivate the Belt Minder so that it never reminds you again, or at least until your reactivate it...
The first method, temporary deactivation, or one time disable: After you have started your vehicle, buckle and then un-buckle your safety belt. Be sure to buckle back up.... This will disable the Belt Minder only for that ignition cycle.
The second method, permanent deactivation: There are 9 steps you need to follow to deactivate or activate your Belt Minder system. Before doing so, make sure that:
* The parking brake is set.
* The truck/car is in Park (automatic), Neutral (manual).
* The ignition is OFF.
* All doors are closed.
* The driver's safety belt is un-buckled.
* The parking and headlights are OFF.
Then follow these 9 steps:
1. Turn the ignition switch to ON, but DO NOT START.
2. Wait for the safety belt warning light to go OFF(1-2 minutes).
Steps 3-5 MUST be completed within 60 seconds!
3. Buckle, then un-buckle the driver's safety belt 3 times, ending with the belt un-buckled.
4. Turn on the headlights, turn off the headlights.
5. Buckle, then un-buckle the driver's safety belt 3 times, ending with the belt un-buckled.
After step 5, the Safety Belt Warning Light will be turned on for 3 seconds.
6. Within 7 seconds of the safety belt warning light turning OFF, buckle then un-buckle the safety belt.
This will disable the Belt Minder if it is currently enabled, or enable the Belt Minder if it is currently disabled.
7. Confirmation of the disabling of the Belt Minder is provided by flashing the safety belt warning light 4 times per seconds for 3 seconds.
8. Confirmation of the enabling of the Belt Minder is provided by flashing the safety belt warning light 4 times per seconds for 3 seconds, followed by 3 seconds with the safety belt light off, then followed by flashing the safety belt light 4 times per second for 3 seconds again.
9. After confirmation, the deactivation/activation of the Belt Minder procedure is complete."
Originally Posted by ryaneverk2
Kwik's not afraid of the rumored airbag/universe decompression/explosion/catastrophe!?
I heard about that too. Checking under the dash on my '99, there is no passenger side airbag. Of course there is one in the steering wheel, but I hope that Ford was smart enough to realize that if the truck is moving in the first place then SOMEBODY HAS TO BE DRIVING IT.
I've never rear ended anyone in my life, I practice safe following distance and then some.
Plus the truck weighs 10,000lb and if an altercation should occur it would be picking that ricer out of it's teeth. <!!! Besides, I have never rear ended anyone in my life, I practice safe following distance and then some. And I have a 10,000 lb truck. It would be picking that ricer out of it's teeth.
My parking brake light was on. As I posted above, I got all of the correct confirmations, just didn't see any difference in the chime. Is that procedure for driving around without your belt? I don't do/haven't done that so maybe that's why I don't see the procedure's effect. Oh well, look out plug, you're next.
