Leveling Coils
Old Feb 16, 2006 | 09:33 AM
rocky35's Avatar
rocky35
Leveling Coils
I have a 1996 F-150 4x4 with a 302. I am currently running 32X11.50-15 BF Goodrich all-terrains. If I install these leveling coils would I be able to run 33x12.50-15 BF Goodrich mud-terrains??
Old Feb 16, 2006 | 03:24 PM
mdjohnson's Avatar
mdjohnson
Leveling coils, no. I have the Skyjacker 2" suspension lift and I'm able to run 33X12.50-15 tires with no rubbing. Pro Comp also sells a 2" kit.
Old Feb 17, 2006 | 11:13 PM
whatdyisit's Avatar
whatdyisit
Aren’t most leveling coils 2 inch? I think you should be fine with the 33's. They might rub a bit but you can always trim the bumper.
Old Feb 18, 2006 | 02:52 AM
TexasGuy001's Avatar
TexasGuy001
The leveling coils I got from Superlift are approxiamtely 2 inch lift. Mine gave me more than 2 inches. All the leveling coils I have seen are about the same thing. The only 2 inch I know of other than that is a body lift. There is also a 3 inch body lift. Then there is 4 6 8 inch suspension lifts. I would advise against body lifts. I don't like them. They don't look right. Also, the center of gravity is changed and the stock suspension is soft so they don't handle as good. I know someone with a 4WD Bronco that is running 33 12.50 15 BFGs with no lift. On my truck the bumper is spaced out an inch or so due to the grille guard mounting brackets. If you don't have a grille guard you can always come up with something solid to use as a spacer to put the bumper slightly forward.
Old Feb 18, 2006 | 05:19 PM
Ford4x4-JD70AB's Avatar
Ford4x4-JD70AB
I'm not sure about leveling coils, but i would recomend a rough country 2.5" suspension lift kit. I got one for my truck and it works great and will clear 33" tires (although i only have 31" right now). Plus they are priced decently. The kit raises the front end 2.5" and the back 2" and really levels out the truck nicely and comes with all new shocks, coils, brackets,and hardware. Ive heard people having alignment problems with coil spacers but Ive never used them so I dont know. The wheels can also make a difference on tire fitment.
ford4her
Nov 15, 2014 01:01 PM
Stangfire
1997 - 2003 F150
Dec 1, 2011 05:56 PM
Jesters Court
All Other Items for Sale
Feb 10, 2010 06:12 PM
Ford94Bronco4x4
1978 - 1996 Big Bronco
Apr 23, 2006 09:31 PM
Ken00
Aug 25, 2003 05:49 PM
