Too much blowby
Old Feb 15, 2006 | 08:40 PM
fivestring63's Avatar
fivestring63
Too much blowby
83 F100 302 has so much blowby that i have to unhook the blowby hose from my air cleaner because it's saturating the air filter. I've chanbed the pcv valve for the 2nd time to make sure that wasn't it.
Blowby is a good indication that the rings are bad, but I did a compression check and got 135 on all of them. I don't understand how there's so much blowby with that good compression.
Old Feb 15, 2006 | 10:30 PM
wintremute's Avatar
wintremute
Maybe a crack or deep score in the lower part of a cylinder that wont show on a compression test at tdc? Just a guess but seems feasible.
Old Feb 17, 2006 | 10:50 PM
fivestring63
HMMMM, very good answer. I never thought of that. I'm thinking of just going ahead and doing a rebuild, but first I want to get an oil pressure gauge and see what that is.
Old Feb 18, 2006 | 10:48 AM
STACK86's Avatar
STACK86
Blowby
I also had a significant blowby problem on my 1986 302.
The compression check was good, but I tore the engine anyway and found all the oil rings frozen, #8 cyl was the worst.
After the rebuild I moved the PCY return to the middle of the intake as recommended by many on this forum.
Problem solved and engine runs stongly.
Good luck.
Old Feb 18, 2006 | 07:39 PM
fivestring63
Whenever I can get the money and a spare vehicle to drive, I'm just gonna go ahead with the rebuild. I'll let you know what I come up with.
DieselCamper
Aug 15, 2016 11:36 PM
SidecarFlip
Transit Connect
24
Apr 17, 2016 08:50 PM
Robrt32
Apr 2, 2014 10:30 AM
jdasilva644
16
Mar 1, 2010 09:20 AM
fmc400
Feb 2, 2007 09:15 PM
