Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
MIG welder
Old 11-15-2002, 09:19 PM
albertafarmer's Avatar
albertafarmer
albertafarmer is offline
MIG welder
I have a dead MIG welder, anyone know if there fixable, worth fixing, or should I just trash it and buy a new one.
Old 11-15-2002, 10:48 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
MIG welder
Kind of depends upon what is wrong with it. As far as help on fixing it I don't know if anybody here would know how but you never know. There may be a few service people here.
I can usually find out what is wrong with a piece of equipment like that if it is sitting in front of me and I have my tools, instruments, and time. Unfortunately I don't know anything specific about MIG welders.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old 11-15-2002, 11:21 PM
albertafarmer
MIG welder
Thanks for your input Torque1st. I took the cover off, no noticably burnt wires, the light comes on when the master switch is turned on, just no wire feed when the trigger is pulled. I don't have a wireing diagram, but it seems to be getting power to all the right spots. May be the wire fed motor is shot, if so it should be replacable. thanks again, I will look for a repair shop.
Old 11-16-2002, 03:31 AM
Torque1st's Avatar
Torque1st
Posting Legend
MIG welder
Track down the trigger switch connections. The gunswitch may be bad or a wire broken. You can get replacement parts for those.
Old 11-16-2002, 09:59 AM
WYStroker's Avatar
WYStroker
WYStroker is offline
MIG welder
>worth fixing
It would help to know what brand and model of welder you have. Also how old it is and what it was doing the last time it worked or what it was doing when it died.
Old 11-16-2002, 10:34 AM
theonlybull's Avatar
theonlybull
theonlybull is offline
MIG welder
did it just happen? or has it kinda acted up a bit? starting and stoping every now and then??
we tend to have to replace our whip every 3 or 4 years on our miller, the trigger switch will burn out, or a wire will break due to the whip being flexed so much.
take your machine to where you bought it, or a welding supply shop and ask them to take a quick look at it. they are the one's who fix them and should be able to give you advice.
Old 11-16-2002, 08:25 PM
albertafarmer
MIG welder
Thanks for input. The front says' GEM dual MIG 120 made in Italy, other than that I have no other info on it. I dug it out of a garbage dumpster. It looked to good to leave there. Do you know what the voltage at the feed motor should be? I'm getting about 12.5 volts but think there should be more. Will keep you advised of any progress.
Old 11-19-2002, 10:52 PM
angus's Avatar
angus
angus is offline
MIG welder
Is there any identification on the feed motor? Maybe you can find specs on it. How about contacting the manufacturer of the welder? Usually the user's manual will have a wiring diagram. Maybe you can find the local distributor or retailer and get a manual.
Try disconnecting a wire from the feed motor, and measure the resistance. It could be worth taking the motor apart and looking for what failed (might be something simple, like a thermal breaker), or take it into a shop that repairs welders: maybe they can supply a replacement.
If the feed thang turns out to be hopeless (like more expensive than the welder is worth), you could always use it as a stick welder.
Old 11-21-2002, 08:18 PM
albertafarmer
MIG welder
Iv'e tried to find the manufacturer with no luck. I tried "Google" search, with both "MIG welders" and "GEM welders", nothing comes up. Any advice.
Old 11-21-2002, 09:30 PM
alanscott's Avatar
alanscott
alanscott is offline
MIG welder
I've seen "Clarke" brand welders that were stamped "Made in Italy", I wonder if it might be the same unit under a different name.
A quick search located a entire page of them, do any of these look the same?
http://doityourself.com/store/clarke_vp.htm
Old 11-21-2002, 09:46 PM
angus's Avatar
angus
angus is offline
MIG welder
How about calling every welding supplier or repair shop in town, and ask if they recognize it?
If it was my problem, I'd have a go at drawing my own schematic diagram. Once I figured out how it was supposed to work, finding the problem wouldn't be too hard.
Old 11-28-2002, 09:33 PM
albertafarmer
MIG welder
[updated:LAST EDITED ON 28-Nov-02 AT 10:34 PM (EST)]Well I took my welder to a repair shop in Edmonton to have an estimate done on repairing it. They wanted $125.00 just to look at it, so I brought it back home. I'll put it on my bench, get my trusty volt meter and start tracing the wiring out. There is a board with a bunch of resisters and diodes on it that might give me some trouble, don't know what their supposed to do or voltage on them. Worst case, I'll salvage all the copper out of it, can get about $1.00 per pound for it. Thanks for all your input, it was very informative and helpful.
Old 12-01-2002, 01:05 AM
redneckdieselmechanic's Avatar
redneckdieselmechanic is offline
MIG welder
GM4WALLS
Paint & Bodywork
01-10-2014 11:46 PM
AXracer
07-18-2012 08:19 PM
preppypyro
Paint & Bodywork
17
10-02-2005 09:52 PM
BradysDad
Garage & Workshop
02-07-2005 12:27 PM
maa139
Garage & Workshop
05-07-2004 03:31 AM
Quick Reply: MIG welder
