460 with overdrive?
Old May 14, 2001 | 05:56 PM
rsjohnsn's Avatar
rsjohnsn
460 with overdrive?
I have a 460 and C-6 in a '76 F-250 4X4 HighBoy that needs an overdrive automatic in a bad way! Is there an auto that will work? Or is it possible to install a late model computer controlled tranny and make it work or is there any add on overdrive units that will mate to my C-6? Everybody has helped alot in the past and I know you can help me on this one!
Thanks for your help
Scott Johnson
Old May 15, 2001 | 11:14 PM
4byford's Avatar
4byford
460 with overdrive?
Have a 77 and am considering the same issue- I think that given the price and durability of later OD automatics, and the retrofit issues (linkages, electronics if needed), and the unique fact that highboys have a divorced transfer case, I would consider putting an add-on OD unit behind your C-6 (Gear Vendors and others are available) I THINK- this is a mental exercise only at this point- that by shortening the short driveshaft between tranny and NP 205 that you can get one in there. Anybody out there done this? They make a Gear splitter box that goes in FRONT of the NP 435 that would also work in these applications- gives you 8 speeds. Just some ideas...
Old May 16, 2001 | 12:42 AM
madcow's Avatar
madcow
460 with overdrive?
DerekShiekhi
General Automotive Discussion
Feb 1, 2016 01:22 PM
Dr. Johnson
Nov 14, 2015 08:14 AM
johnson.jeff.a
15
Oct 12, 2015 04:00 PM
srpservices
Sep 1, 2015 04:27 AM
brown79
Jul 22, 2005 12:03 AM
