C6 Help
Old Aug 28, 2015 | 10:31 PM
srpservices's Avatar
srpservices
C6 Help
i have a c6 in an off road truck that seems to work fine but when getting up in rpm it will just act like it hit neutral. wont go in any gear. doesnt make any noise or anything. pulled it back checked fluid and it was a touch low so i topped it off. tried again and it went in reverse and forward good. no hesitation or noise. drove about half mile and it acted just like it hit neutral again. loaded it up brought it home and drove it off the trailer and in barn.
have had some say to check the filter and gasket. i did change it before it was taken out to drive.
been doing alot of reading and havent found anything close to this.
its a 4wd trans with 205 t case 460 motor.
thanks for any input
scott
Old Aug 28, 2015 | 10:36 PM
stuart1's Avatar
stuart1
The breather may be plugged and if so it will give a false fluid level reading.
Old Aug 28, 2015 | 10:46 PM
srpservices
i will check that out
thanks stuart1
Old Aug 29, 2015 | 08:00 PM
srpservices
pulled the pan today and found in the bottom what looks like black crumbs of plastic.
also took filter off and did find a rippled area on it that could very well have not been sealing correctly.
not sure what the black crumbles are. almost look like plastic but could be clutch pcs.
guess i will be pulling it out and have it checked over.
will post what i find
thanks scott
Old Aug 29, 2015 | 08:04 PM
stuart1's Avatar
stuart1
Curious. What kind of filter is in there? Gad I hope you don't say Dacron.
Old Aug 29, 2015 | 08:44 PM
srpservices
dont know what it is. know i wont be getting one from the same place to be sure i dont get one like it lol.
what is a good one to get
Old Aug 29, 2015 | 10:02 PM
stuart1's Avatar
stuart1
Is it metal or cloth?
Old Aug 29, 2015 | 10:13 PM
srpservices
its a metal one from one of the local auto parts
Old Sep 1, 2015 | 04:27 AM
Crop Duster's Avatar
Crop Duster
I believe the #1 selective thrust washer. that's the one behind the front pump, is made from nylon or something similar. The replacements are black.
hayden01
Aug 13, 2011 04:35 PM
edsf100
Jan 25, 2011 07:58 AM
big_ford_rednek
Feb 22, 2009 11:13 PM
Lane Dexter
13
Nov 15, 2004 11:36 AM
roscoe
Oct 9, 2003 07:22 PM
