Carriage Works Grill Replacement
Old Feb 14, 2006 | 06:09 PM
is300wrx's Avatar
is300wrx
I just purchased the Carriage Works Grill that replaces my bar grill. Anyone have any experience with this? This is NOT a bolt over and it requires some "cutting" I guess. I also got the bumper grill to match. Any heads up would be nice
Old Feb 14, 2006 | 11:38 PM
New To Ford's Avatar
New To Ford
No cutting.....you just unbolt the old plastic one and bolt on the new one....the only alteration is 4 screws in the bottom of the grill surround. Very easy....about 45 min, if you take your time and follow the instructions. The nice thing about this grill, is you dont have that small piece of colored plastic between the grill and the surround (the grill covers it all).
Old Feb 15, 2006 | 08:12 AM
is300wrx's Avatar
is300wrx
ok because their website considered this grill "cutting". Thats why I was a little nervous. But thanks for the heads up.
P.S. Would this grill go with the OEM Ford bugshield?
Old Feb 15, 2006 | 02:19 PM
HOLESHOT1's Avatar
HOLESHOT1
Yes, it will fit. The surround remains the same factory piece. I installed both upper and lower grill replacements from carriage works last year and have had no problems. Ive had the factory lo-profile bug shield since day one, and nothing changed. The grill combo looks great if you're into a clean look. My FX4 is silver and the billet blends everything together.
Old Feb 16, 2006 | 08:35 PM
shotout's Avatar
shotout
Can you tell me the part number for that grill. and how much it cost u. I have a 2005 fx4 with the bar grill and they are telling me thats all i can out is the inserts in it. I dont care for the look of that.
Old Feb 16, 2006 | 08:51 PM
efiguero's Avatar
efiguero
Holeshot1,
DO you have any pictures, I have a silver FX4 aswell and would be interested in what it looks like.
Thanks
Old Feb 16, 2006 | 10:27 PM
is300wrx's Avatar
is300wrx
http://www.carriageworksinc.com/Ford.jsp
http://www.carriageworksinc.com/products/42101.html (replaces the center on both types of grills: bar or honeycomb. Requires cutting. I got this one and a bumper grill to match as well.
<TABLE class=tborder cellSpacing=1 cellPadding=4 width="100%" align=center border=0><TBODY><TR title="Post 3413149" vAlign=top><TD class=alt1 align=middle width=125>HOLESHOT1</TD><TD class=alt2>Yes, it will fit. The surround remains the same factory piece. I installed both upper and lower grill replacements from carriage works last year and have had no problems. Ive had the factory lo-profile bug shield since day one, and nothing changed. The grill combo looks great if you're into a clean look. My FX4 is silver and the billet blends everything together.</TD></TR></TBODY></TABLE>
Can you take a pic of the grill and the bug deflector? I am thinking of taking it off since the only black that will match the deflector is my lower spoiler...Still skeptical about it. I also have the eyelids on there and the eyelids and the deflector doesnt want to fit too well with each other. The bug deflector already scratched the eyelids quite badly. But once the hood is down, you cant see it thank god. I was planning on removing the deflector tommorow, taking the eyelids off, sanding it down, primer it, paint it, wet sand it, clear coat the *******, and put it back on with the grill. Please post a pic for me because if I like the look of it, I wouldnt bother repainting my eyelids (will have to due to the scratching. If i keep the deflector on, I dont need to repaint.) Thanks fellows
Old Feb 19, 2006 | 08:39 AM
is300wrx's Avatar
is300wrx
installed and it looks AWESOME!!
p.s. I scratched the ***** out of the bumper because one of the screws that goes under the outer shell of the grill wasnt sitting flush to the outer shell...So touch up paint time..
Old Feb 19, 2006 | 12:18 PM
shotout's Avatar
shotout
What kind of grill did you have before the new one. I guess what im asking is what did it look like. They told me that if you have whats called the work truck grill that that grill will not fit. Im just trying to figure out what i have before i order something i cant use.
Old Feb 19, 2006 | 02:03 PM
is300wrx's Avatar
is300wrx
if you have a F-150, its either a Honeycomb grill (XL, XLT, Lariat) or a Bar Styel Grill (STX, FX). This partnumber can be used for any grill for a F-150. It replaces the whole grill assembly.
Old Feb 19, 2006 | 06:18 PM
HOLESHOT1's Avatar
HOLESHOT1
yeah, is300wrx is right. This model replaces the whole bar assembly. It can be used with either stock style. The overlay ones are only good for the honeycomb grills. I'll try to get some pics of the grill and deflector up soon. I'm probable the worlds biggest procrastinator. Heck, I've only had the truck for 2 years and have yet to set up a gallery for the sight. I'm having a Line-X sprayed in shortly and I have a tonneau cover on order so I'll do it all at once.
but back to the carriage works, shotout is right on with the attached links.
Old Feb 19, 2006 | 06:29 PM
is300wrx's Avatar
is300wrx
I just put the deflector on and i think it does flow nice with the black mirrors and the black running boards. It balances out the top part of the truck...I just wish I can take back and screw those scews in tighter so that I didnt scratch up my loewrbumper when i closed the hood....Damn it.
Old Feb 21, 2006 | 02:46 PM
HOLESHOT1's Avatar
HOLESHOT1
Don't bother putting those four rubber stick-on pads either. There supposed to line up under those four screws incase the hood drops down too far. Problem is, after one or two good washes, they fall off and you're left with four sticky round circles on your bumper instead. Of course, that would be better than the scratches you've "installed". Sorry.
Old Feb 21, 2006 | 03:48 PM
is300wrx's Avatar
is300wrx
ha those are for that purpose? never said anything about it in the instructions! Oh well, touch up paint, here i come
