Dually rims
Old Feb 14, 2006 | 04:00 PM
blueeyes2478's Avatar
blueeyes2478
Dually rims
Has anyone ever have a rim crack right thru.One of my front rims on my dually cracked in 2 spots.Also does anyone know where i can get a cheap front rim for it.Ford wants an arm and a leg,then some.
Old Feb 14, 2006 | 04:15 PM
clintbonnie's Avatar
clintbonnie
I would try e-bay.com.. use key words Ford F350 wheel.. there are over two hundred entries... one of them might work..
Old Feb 14, 2006 | 04:40 PM
blueeyes2478
Thanks clint,but i was looking even cheaper then that as its 306.00 on ebay and i can get it at the dealer for 367.00.
Old Feb 14, 2006 | 05:06 PM
h2guy's Avatar
h2guy
I had some luck a few years ago at Marks (don't know if its under Auto Salvage, Junkyard, or what now) in Windsor Locks.
Must be other salvage yards around you.
Old Feb 14, 2006 | 05:11 PM
blueeyes2478
Thanks h2guy,there not to far from me.Ill check.
Old Feb 14, 2006 | 05:47 PM
whitesdford's Avatar
whitesdford
Ive got the factory dually rims off my truck. Two fronts and two backs. They are in great shape, comes with the lug nuts, caps, etc. I changed over to aluminum rims last year. I'll sell them all to ya for what ebay wants for one wheel, haha. PM me if your interested.
Old Feb 14, 2006 | 07:49 PM
freaknastyracing's Avatar
freaknastyracing
Summit sells an identical wheel to the stock ford 5 star. I too had one crack right in two. Then a second rim cracked. I noticed it one day polishing the rim when I saw brake dust seeping through the spoke. The wheels from summit are Eagle alloys p/n
AEW-0349-7688 $136.50 each, and summit ships ground free!!! There great because they are polished on both sides unlike the ford rims so I bought 4 and can now rotate the front two with the back outer two. Also you might want to check the wheel bearing hub assembly that could be causing the weight of the diesel to rid incorrectly. if you jack one side up front and shake the tire from top to bottom it is or is going bad. Stealership price:$380, napa $460, Advance $289, those are all with the wheel speed sensor for ABS in it.
Old Feb 16, 2006 | 07:21 AM
blueeyes2478
Thanks for the help.Freaknasty i looked on summit and cant seem to find the rim i need.
Ill keep looking.
Old Feb 17, 2006 | 09:32 AM
freaknastyracing
Thw summit web site and mgazine doesn't list all the parts thary stock or can get. You should just call them and give them the part number. I will do somew research also and let you know.
Old Feb 17, 2006 | 03:34 PM
blueeyes2478
Thanks so much freaknasty,i called them and they do have it.So it looks like ill be going with them.
I just have 1 question for ya tho,do they look like the stock wheels.Cause im only buying one wheel,so i dont what them to look at differant from the stock ones.
If they are an exact match,i will buy it.
Old Mar 21, 2006 | 04:24 PM
freaknastyracing
blueeyes2478 your welcome, I bet that price puts a smile on your face huh? They are identical with two exceptions. Both sides are polished unlike the FORD ones so you can rotate it with out having a dull side and the protruding side, like if you had it on the front has load range casting in it. So if you still use the factory lug covers you will be fine. I did find they are quite brighter than mine, but I use my truck in some preaty harsh conditions, so I bought 4. Anything else let me know.
crosswarrior
Oct 19, 2023 03:58 PM
totavikid
Nov 26, 2013 07:46 PM
47duallyFL
1947 and Older Ford Trucks
Nov 6, 2013 10:24 AM
bruali
Aug 8, 2012 11:30 PM
Hardcore Sledder
Jan 5, 2004 10:15 PM
