Hello I just purchaced a 1975 f-100 custom. Down the road it runs fine but is very sluggish/coughs and sputters and sometimes dies on take off from stop signs, but will idle fine in gear but try to accelerate and its a battle. I am going to give a complete full tune up tomorrow even though all components look to be newer i would just feel better. What I am wondering is where the timing should be set. its all stock automatic trans truck. any help or suggestions would be great Thanks
My understanding is that timing specs vary...but a good rule of thumb is 8 to 12 degrees. I'd suggest you start at 8 and work your way up until you find the ideal setting.
As for the take-off problems...check your accelerator pump. It sounds like you've got a problem there, considering that it will idle and run good at speed.
Could anyone help me with a starting point on setting a remanufactured 2 barrel ford carb on my 1975 390ci. all stock engine. And also timing setting. thank you for any help thanks.
I guess im not sure, im just going off what the seller told me. How can I tell the diff. for sure? I hope its right im buying all the tune up stuff today. Hmmmmmmm.
My title sais 1975 but the sticker in the door sais 9/74.
I think it was changeover time and i got one without points. I checked again and nope nuttin in there.
Thanks though, anymore input will be appreciated
