Sponsored by: Auxito
Auto door lock disable
Old Feb 13, 2006 | 02:04 PM
Fordteamone's Avatar
Fordteamone
Good day all. Is there a way to disable the auto door lock? We are working out of a 2000 F150 XLT and when we move the truck forward 50 yards for the next project the doors lock. I run forward with the door open and when I close it the truck is locked. Thanks!
Old Feb 13, 2006 | 02:15 PM
Patatoe1's Avatar
Patatoe1
I think this is how you do it.
1. Start in the truck with all doors closed and the key turned off.
2. Put the switch in the on position and press the door unlock button 3 times.
3. Put the switch in the off position and press the door unlock button 3 times.
4. Put the switch in the on position, you should hear a quick note from your horn.
5. Press the door unlock button 1 time then press the door lock button 1 time.
6. You should hear a short note from your horn indicating that the auto-lock system is disabled. If you hear a short note then a longer note from the horn then the auto-lock system has just been enabled.
7. Turn the switch to the off position. You will hear a short note from the horn to let you know that the system has been changed.
8. These steps should be done within 30 seconds in order to properly activate or deactivate the feature.
Old Feb 13, 2006 | 02:16 PM
KingRanchMan02's Avatar
KingRanchMan02
Deactivating/activating the autolock feature
Before following the procedure, make sure that the ignition is OFF and
all vehicle doors are closed.
You must complete steps 1-7 within 30 seconds or the procedure will
have to be repeated. If the procedure needs to be repeated, you must
wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will
chirp once if autolock was deactivated or twice (one short and one long
chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the
procedure is complete.
Old Feb 13, 2006 | 02:28 PM
Fordteamone
You all are awesome! Truly a great site. Thanks for the help. I will give this a try this weekend.
Old Feb 13, 2006 | 02:42 PM
Patatoe1's Avatar
Patatoe1
This weekend? Give it a try now if you can only takes 30 seconds.
Old Mar 10, 2006 | 02:15 PM
Fordteamone
Well sorry to take so long getting back, I worked at different sites and took longer to get back to the F150 Thanks to you all! This worked great. This is still the best site for fords. Keep it up.
slowlanemcvane
Nov 4, 2024 10:05 AM
jocko165
Oct 26, 2015 06:36 PM
campingpaul
2015 - 2020 F150
17
Oct 13, 2015 05:11 PM
Vinford
Apr 2, 2015 10:25 PM
Bootlegger's Deluxe
Nov 8, 2010 12:08 AM
