tranny swap ?
Old May 28, 2001 | 03:46 PM
easyi812's Avatar
easyi812
tranny swap ?
Hey people,I have a 1977 F250 highboy 400 c.i. C6 and want to replace the tranny with a NP435 4 speed.I have purchased a 77 F250 with this 4 speed and wonder if it will be a straight swap or if I will have to cut the floorboard. The truck has everything I need clutch linkage,pedal,drive shaft etc.Any thoughts will be appreciated.Thanks Curt
Old May 28, 2001 | 09:27 PM
dinosaurfan's Avatar
dinosaurfan
tranny swap ?
Curt, the 69 and both the 71s that I've had all had a large sheet metal cover in the middle of the cab that could be unbolted to work on the shifters or transmission. The shift sticks came up through holes in that plate. If the newer trucks don't have this you will have to do some cutting. DF
Old May 28, 2001 | 09:47 PM
bigfordman70's Avatar
bigfordman70
tranny swap ?
It should be a straight swap, including the hole in the tranny hump. Don't forget to swap the manual flywheel over.
BFM
Old May 28, 2001 | 10:10 PM
bigfordman70
tranny swap ?
rugermack
Oct 11, 2014 09:29 AM
CharlieM35
Oct 4, 2012 07:12 PM
godblessmud
Jan 30, 2008 07:09 PM
westbrookhvac
Jul 9, 2003 06:45 PM
