problems still.
Old Feb 12, 2006 | 12:09 PM
bkilian5894's Avatar
bkilian5894
problems still.
i posted a thread last month titled "stumped need help", thanks for the tips but i am still having the same problem.
" i am new here and hoping to find some help. i have a 2wd 2001 ford ranger v6 3.0,automatic, with around 69,000 miles on it. the problem is @ about 3500 rpm it cuts out, sometimes multiple times in a row, i changed fuel filter, and it kinda helped but not much. it isnt pulling any codes no check engine light nothing. it feels like it is trying to die. i changed the tranny fluid thinking that might be the problem but there was no metal in the pan. some ppl have suggested that it could be fuel starvation, is this possible? i really dont want it to be the tranny.
please tell me what u think is wrong. any help will be greatly appercaited."
it is only getting worse and still no codes, now it really doesnt matter what rpm it is at, weather warm are cold. now it is lossing about 400 to 1000 rpm's when it trys to die. the jerkin problem is getting anoying. ive changed all filters, fluids, and plugs and wires, and i am running outa ideas, this thing wont even give me a clue to whats wrong. still no codes.
Old Feb 12, 2006 | 05:44 PM
pintopower8's Avatar
pintopower8
when you say it cuts out,does it shift still, or does it just stay in one gear? Check your sensors too, usually when a sensor goes, you won't get a code, I know I didn't.
Old Feb 12, 2006 | 06:01 PM
savagefan's Avatar
savagefan
How' s your fuel pressure?
Old Feb 12, 2006 | 07:17 PM
natebaker's Avatar
natebaker
Check the MAF(possibly clean it with some electronics cleaner). I'm sure you can find a detailed thread in this forum for cleaning it.
Old Feb 13, 2006 | 12:37 PM
pawpaw's Avatar
pawpaw
Well if all the electrical checks in the last thread were done without results, I'd do a fuel pressure test & see what gives.
Since the problem has gotten worse, I'd also have the computer rechecked for any set, or pending codes, even if you don't have a CEL (Check Engine Light).
If those actions don't provide a clue, I'd look to basic things, like power interrupt problems to the basic things, like the fuel pump, fuel injectors & coil pack.
If you could make loan of a scan tool, lik the Actron CP9145, from your local autoparts store, (most in my area have a "Loan-A-Tool" program for a refundable deposit), hook it up & drive until the vehicle act up, the scan tool can store & playback all of the stored data on sensors it was monitoring when the problem happens.
From that you should be able to isolate the problem to a system & if lucky maybe even the part.
Let us know what you find.
Old Feb 16, 2006 | 03:17 PM
bkilian5894
yes it still shifts
Old Feb 16, 2006 | 04:24 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I'd be investigating the possibility of low fuel pressure. Go get a gauge and check it.
Michael Paul
Aerostar
17
Jul 23, 2007 09:56 PM
lp92chateau
British Columbia
Nov 19, 2006 02:02 PM
strokd
Apr 14, 2006 10:55 PM
Ingy
Mar 31, 2006 11:28 PM
JDemo-in-NC
Dec 30, 2005 05:06 PM
