speedo reading high
Old Apr 30, 2012 | 07:49 AM
needhelp49's Avatar
needhelp49
speedo reading high
my speedo is reading about 5 to 8 mph higher then real so it says 60ish when I'm going 55. Do i go up in teeth on the gear or down?
Old Apr 30, 2012 | 07:57 AM
GreatNorthWoods's Avatar
GreatNorthWoods
More teeth slows it down. Usually one tooth is worth about 5 MPH so you may need a gear with two more teeth...
Old Apr 30, 2012 | 01:09 PM
ZOOT's Avatar
ZOOT
I have a C4 tranny and I got the repo cable with the gear that was recommended by Sacramento Vintage Ford and my speedo reads 5mph slower than my acutal speed. I just keep that in mine when I'm driving, small detail as far as I'm concerned.
Old Apr 30, 2012 | 08:46 PM
mytbtruck's Avatar
mytbtruck
Check out transmissioncenter.net it gives a lot of info how to determine gears with rear end ratio and tire size. It may help or not, worth looking at.
Old Apr 30, 2012 | 09:39 PM
needhelp49's Avatar
needhelp49
my wife wont drive it till it's right she's weird that way wanted brakes also
Old Apr 30, 2012 | 09:42 PM
critterf1's Avatar
critterf1
That's one way to keep it to yourself.
Old May 1, 2012 | 12:43 AM
ben73058's Avatar
ben73058
Hey Wisconsin,
If you don't get where you want by swapping out the
speedo gears - there is a different route I learned about in
trying to get our's to work. We've got a wireless programmable speedo -
It's pretty neat. You put whatever speedo gear you want in your trans &
you put the wireless sender unit in where the cable would go on the trans. & you go out to a highway with known distance markers. You punch the setup button & drive it two miles at 45 MPH or so & it calibrates itself & you get the right speed showing on your speedometer.
This was my first experience with these programmable speedos & it certainly worked like a champ. I got mine from Egauges.
Good luck over there.
Ben in Austin
1950 F1
KsHighboy
19
Mar 29, 2016 05:46 PM
zingerr
Apr 29, 2013 06:35 PM
customfoam
Dec 19, 2004 05:15 PM
71LTD390
Sep 1, 2004 08:13 AM
jimandmandy
Nov 13, 2002 10:24 PM
