1978 - 1996 Big Bronco
1990 front axle U-joint
Old Feb 11, 2006 | 06:42 PM
re_fill's Avatar
re_fill
I started a thread trying to figure out how to remove the hub and axle assembly in order to change one of my U-joints. Great response, many thanks, but before I do that, do I have to remove the axle? Can I replace the U-joint without removing the axle?
I can see it, I can move it, I can feel that it is shot. If there is a way, how do I remove the caps that cover the snap rings without wrecking anything, and is this possible?
It is the outside joint on the passenger side, if that means anything.
Thanks in advance, this forum has already saved me big $$$$$$$$$$$$.
Old Feb 12, 2006 | 02:03 AM
greystreak92's Avatar
greystreak92
Wow, I guess you could try but why make the process more difficult? Honestly, removing the axle will be less difficult than trying to replace the U-joint with it in place.
Old Feb 12, 2006 | 10:26 AM
wozxxx86's Avatar
wozxxx86
i agree...lol ive had to take a plasma cutter to onea my u joints..so lol best just take it out befor u spend 6 hours tryin to pound it out then end up breakin sumthin. jus my 2 cents. gl
Old Feb 12, 2006 | 04:07 PM
dwoodler's Avatar
dwoodler
I had to use my 20 ton press to press the ujoints outta my 79 axle when I changed the u-joints....
Wobbling the axle around probably wouldn't do the seal any good either. Then you'd have to pull the axle to replace the seal.
Old Feb 12, 2006 | 06:55 PM
re_fill's Avatar
re_fill
Thanks for the info. Out with the axle.
Steven Stocki
Nov 27, 2016 09:39 PM
jplinville
Oct 17, 2016 08:41 PM
Snuggyworm
Jun 4, 2014 02:17 AM
MikeFlorida
May 13, 2007 06:52 PM
Kalashtar
Jan 18, 2006 12:11 PM
