Codes, codes, and more codes.....Help decode
Old Feb 10, 2006 | 12:34 PM
SilverBullet131313's Avatar
SilverBullet131313
Hey guys.....just got my DP Tuner 4 position chip in a few days ago...(Stock, 40, 80, 120) and absolutely love it. Been easy on it..but of course played a little in each setting. SO just keeping up to date in case it helps...and mods are 2001 F250 7.3, AIH plug, 4 inch mbrp exhaust turbo back, napa 6637 filter, BD accumulator Body in tranny, zoodad mod, wicked wheel. SO i got my codes cheked today and got quite a few. Not sure how long they have been in there or what ones are chip related etc etc So please help decifer what they are and what is teh fix if need be.
P0603
P0478
P1248
P0470
P1211
P0541
ANd guy said something at idle my map pressure on the screen he had was 12 ..which he said was low....said it should be 15-16 normally at idle. So not sure what that means or whatever just relaying what he said going by the scanner.
So i had codes cleared and will drive for a few days and recheck to see what pops up again. But in meantime...i appreciate all help in figuring it all out.
Thanks
Tony
Old Feb 10, 2006 | 03:22 PM
Budkole's Avatar
Budkole
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0478 Exhaust Pressure Control Valve High
P0470 Exhaust Pressure Sensor Malfunction
PO541 Manifold Intake Air Heater
P1248 Turbo Boost Pressure Not Detected
P1211 ICP Not Controllable - Pressure Abow/Below Desired
Old Feb 10, 2006 | 04:02 PM
hanklin's Avatar
hanklin
Silverbullet
I`m not quite sure how screwed I am but here goes
When I programed my truck I noticed that PO603 was coming up,well fast forward 2 years my tranny is acting strange in the shifting patterns,not always the same.I was told that the codes that didn`t make sence cause they wern`t consistent.Anyway my buddy(mech) looked at her today and we think it is the pcm gone bad,ordered a new one be here on mon. $351.00 sure hope that cures it versus a new tranny
Old Feb 10, 2006 | 04:11 PM
wlihntr's Avatar
wlihntr
P0603 Internal Control Module Keep Alive Memory (KAM) Error- happens when you disconnect the batteries (when you put the chip in)
P0478 Exhaust Pressure Control Valve High- can happen with the turner because of the inreased pressure in the exhaust system
P0470 Exhaust Pressure Sensor Malfunction- can also be set because of over pressure but it may be bad
PO541 Manifold Intake Air Heater-because you removed your AIH. did you reconnect the blue wire back to the realy when you took the red wire off?
P1248 Turbo Boost Pressure Not Detected- could very well be a map sensor problem
P1211 ICP Not Controllable - Pressure Abow/Below Desired- also caused by the turner
Old Feb 10, 2006 | 06:36 PM
PSNut's Avatar
PSNut
Sent u a PM. Need info.
Old Feb 10, 2006 | 07:04 PM
hanklin's Avatar
hanklin
Some of the posts seems to missing,,hope all is Ok
Hanklin
Old Feb 10, 2006 | 07:10 PM
4x4 VANMAN's Avatar
4x4 VANMAN
P0603
P0478
P1248
P0470
P1211
P054
Thanks
Tony
Silver Bullet were these codes setting your SES light on the dash. I just got Jodys chip a month ago, and when I put the go pedal on the wood to pass a slower car or just watch the smoke fly I get the SES light turned on. The light only comes on when doing this and goes off after a couple hours of driving. Havent had the codes pulled yet. Im pretty sure its something to do with the chip, it never happened before. Just wondering if this happens to other people under full throttle. Thanks.
Nick
Old Feb 10, 2006 | 07:13 PM
PSNut's Avatar
PSNut
Hanklin
Likewise Hanklin...can't figure some folks out.
https://www.ford-trucks.com/forums/s...d.php?t=457823
Check out wlintr's response in one of the posts.
Old Feb 10, 2006 | 07:15 PM
PSNut's Avatar
PSNut
Nick
Nick,
Do u have a boost relief valve?
Nut
Old Feb 10, 2006 | 07:19 PM
4x4 VANMAN's Avatar
4x4 VANMAN
Originally Posted by PSNut
Nick,
Nut
Well I do, but its sitting right here infront of me and not on the truck yet. Just got it this week. I think I see were your goin though.
Old Feb 10, 2006 | 07:27 PM
PSNut's Avatar
PSNut
Your on the money Nick...should take care of your problem.
Old Feb 11, 2006 | 12:21 PM
wlihntr's Avatar
wlihntr
give it a rest...you are not accomplishing anything
Old Feb 11, 2006 | 12:27 PM
blueeyes2478's Avatar
blueeyes2478
Comon boys,we are all here to have fun.
Old Feb 11, 2006 | 01:01 PM
PSNut's Avatar
PSNut
I agree ...let's remove this post please...thank you.
c.hawk71
1983 - 2012 Ranger & B-Series
Sep 13, 2014 09:43 AM
jeffvitt
13
Apr 6, 2011 10:08 PM
jeffvitt
Mar 26, 2011 09:36 PM
John7894
Apr 1, 2007 03:40 PM
jacrol
Jun 26, 2003 02:27 PM
