Mounting a C-4 to a Ford/Mercruiser 3.70 (1/2 of a 460)
Using flexplate from Ford 250 I-6, no problem.
Need dimension measured from flexplate face where torque converter bolts to rear face of bell housing where transmission section bolts against.
With this dimension will be able to fab either an adapter plate or a bellhousing similar to a "scatter shield" type bellhousing.
Thanks,
