Modular V10 (6.8l)
V 10 Plug Blowout Poll
Old Feb 9, 2006 | 03:03 PM
superduty lee's Avatar
superduty lee
I read alot about the plug blowout on the V10 on this forum. I don't believe that it's a common problem. I would like to see how many on this forum, have or have not had a problem and what year a mileage you have on the V10.
2002 V10
22,000 miles
no plug problems
Old Feb 9, 2006 | 03:11 PM
ford390gashog's Avatar
ford390gashog
well out of 78 trucks at work , which are all modular engines either 5.4 or 6.8 s far there have been 3 . 2 on the same truck and one on another. however when they got fixed they had 189,000 and 214,000 on them . the trucks were not taken care of very well (bought at auction for 2,000 each) the plugs were very loose . it seems if you replace them at 100k and torque them down there will not be any issues. the biggest problem is the plugs are overlooked and not torqued right. this has always been a issue with aluminum heads but more so with these engines. the other 76 trucks have had zero issues. the plugs get torqued every 50k and replaced at 100K. other little items seem to fail before the engines in these trucks. we stock about 25 IAC valves , plenty of coilpacks and VSS.
Old Feb 9, 2006 | 03:22 PM
SLE's Avatar
SLE
2003
31000 miles
No plug blow outs
Old Feb 9, 2006 | 06:59 PM
DJR 17's Avatar
DJR 17
I had a plug get loose on a 1997 4.6, it didn't blow out, but I heard it before it blew. Whats a VSS? The speed sensor in the diff?
Old Feb 9, 2006 | 07:26 PM
ford390gashog
yes its the speed sensor in the diff.
Old Feb 9, 2006 | 07:29 PM
boxcar1974's Avatar
boxcar1974
2003 V10
56,000 Miles
No plug problems
Plug problems are a modular engine problem not just the V10! The 4.6, 5.4, and 6.8 all have had plug blow out problems.
Old Feb 10, 2006 | 08:25 AM
benr0's Avatar
benr0
57,000
2001 V10
No Plug Problems
Old Feb 10, 2006 | 08:51 AM
terry_opie's Avatar
terry_opie
2001 F250 V10
No Plug Problems...
Old Feb 10, 2006 | 09:04 AM
PurerockRacing's Avatar
PurerockRacing
2001 F350 V-10
48,751 miles
No plug problems
Old Feb 10, 2006 | 11:21 AM
Kennicol's Avatar
Kennicol
2001 f250 55700 miles no plug problem
Old Feb 10, 2006 | 11:52 AM
Munkey's Avatar
Munkey
'02 @ 83k
(Ordered from factory in early Jan., delivered in late Feb. 02)
Still on factory plugs, no problems.
Old Feb 10, 2006 | 12:55 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
No problems.
'01, 22K miles, 5.25 years since manufacture. More like 70K miles worth of air and fuel have gone through the motor.
Changed plugs a few months ago, figuring 5 years was long enough. Two had dirt/moisture in the plug holes, one was pretty rusty and was slightly tough to get out of the head. (see my gallery) I suspect that left until 100K miles, that plug would have come loose and ejected Or the threads would be so torn up on removal that the new plug would come loose pretty quick. Inspected all threads and everything looked fine. Reinstalled with anti-sieze and torqued to 14 ft/lbs. Runs better, especially cold starts.
art k.
Old Feb 10, 2006 | 03:05 PM
ToaDisco's Avatar
ToaDisco
1999 V10
115,000
Blew one plug.
It was avoidable, I heard it ticking but didn't act in time. I didn't know plugs blew on these right after I bought it. If only I found this site before, but thanks to the people here I repaired it with the Timesert kit in the parking lot and all has been well in the past 8k miles or so. I replaced the other nine afterwards and all were tight and the threads were in good shape.
Old Feb 10, 2006 | 03:23 PM
ford390gashog
the timesert kit is great!
Old Feb 10, 2006 | 03:34 PM
krewat's Avatar
krewat
Originally Posted by ToaDisco
1999 V10
115,000
Blew one plug.
Take solace in the fact that shortly after (or even before) it was ticking, the threads were probably gone already.
