Stock Intake & New 4bbl Carb
Hey, all. It's been a while. The trucks been put up for the winter but as spring approaches it's time to gear up for the season.
Question: I want to replace the carb, currently a 2bbl on a 360 with [what is presumably] a stock intake manifold. I want to install a 4bbl, say with a 770cfm Avenger or the like. Before I start dismantling I'm wondering if someone can tell me if all stock 360 intake manifolds are set up for 4bbl carbs or do I need to replace the intake manifold.
Thank for the input.
Originally Posted by ford390gashog
yes the 2bbl intake manifold is stock. but i don't get the rest of your question?
Maybe a stupid question, but both the truck and Ford are new to me.
Originally Posted by bertha66
You will need a 4bbl manifold. I have not seen a 2bbl manifold that would be com[atible with a 4bbl, but you never know about Chevys.
I don't know how else to ask. The truck is at another house and I was hoping to order a carb for the weekend.
Originally Posted by 68 250 Flareside
Thanks, so back to the original question because I'm not being clear: Does a stock Ford 360 2bbl engine have a 4bbl-sized intake manifold inlet on top or a 2bbl-sized inlet. The Chevy had a 4bbl-sized manifold inlet under their 2bbl carb. I do understand a 2bbl inlet will not fit a 4bbl carb.
I would advise you to leave the 2 barrel on the truck. You will dump more gas in with a larger carb, and more out the tailpipe. Rebuild the engine and that could change. Dual exhaust will give you the most return for your buck, on the ol truck. IMHO
John
If you're not concerned with going fast, I would stick with the two barrel. If you want to wake up the old 360 and get some more power, you might want to consider the Edelbrock Performer intake and matching carb, cam, and lifters. However as Jowilker said, just a good freeflowing dual exhaust with the stock intake and carb will probably offer you the best hp return for dollar invested......
Mudshovel_009
23
02-05-2017 01:36 AM
Rusty_S
34
06-22-2016 02:29 PM
76ClydeF100
04-03-2014 10:26 AM
86ford302help
27
04-04-2013 10:19 PM
icuhatn99
02-05-2006 10:35 PM
