headlight problem
Old Jun 9, 2001 | 08:35 AM
red68ranger's Avatar
red68ranger
headlight problem
>Just got to
>have a little fun every
>now and again.
I'm all for having a little fun, but hey, let's not ride them EE's too hard and then put 'em away wet. I know some of us, uhh I mean them, actually don't mind getting their plastic pocket protectors greasy.
About the resistance and current post above, current decreases with increasing resistance. The formula is current equals voltage divided by resistance. Like with other things, it's something you can forget if you don't use it every day. If you ever need it and can't call it up, just think about the extremes--an open circuit with infinite resistance and a dead short which has very near zero. Which allows more current?
Dan Blackwell
Old Jun 9, 2001 | 12:28 PM
jowilker's Avatar
jowilker
headlight problem
Dan, My first born has a EE from NCSU, I got all of my degrees from UHN cumalonglater. :-)
Dr. John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Jun 9, 2001 | 01:48 PM
75fef100xlt's Avatar
75fef100xlt
headlight problem
that silver thing is the horn relay. No other electric boxes on the right side except the regulator.
Old Jun 9, 2001 | 05:07 PM
sparky's Avatar
sparky
headlight problem
>more current?
Hey neat it looks like I screwed up Ohm's Law, I hope my Boss doesnt read this I think I was probably thinking about parallel circuitry, (the more resistors the more the total current in the circuit).
At least that is what I hope I was thinking Few to many "wobbley pop" during the hockey game and then trying to explain electricity
I stand corrected.
The beleive the rest of the post is good. The circuit breaker is tripping and resetting due to excess current draw, or a bad/worn/weak breaker.
Sparky
Old Jun 9, 2001 | 06:34 PM
Charles-65F350's Avatar
Charles-65F350
headlight problem
>resistance.
Most of the time
But don't forget, a light bulb filament is nonlinear. The cold ("off") resistance can be quite low compared to the hot (lit) resistance. Check a standard home 100 watt bulb sometime with an ohmmeter (you'd expect it to be 120v * 0.83 amp = 100 W, thus 144 ohms). It'll be only about 9-10 ohms!
So bulbs that have the voltage reduced due to bad connections may not drop the current as much as you might expect, and can continue to heat the bad connection quite a bit.
-Charles
(a former EE, among other things
Marketmanohyeah1
Feb 23, 2014 01:08 PM
Rustymuffler
Electrical Systems/Wiring
Jan 11, 2007 08:49 AM
hoofangler
Jul 2, 2005 01:06 AM
opjgeorge
Oct 29, 2002 01:48 AM
desperado_18_2000
Feb 20, 2001 05:53 PM
