Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
trickle charger
Old Dec 11, 2002 | 08:24 AM
Fordzlla's Avatar
Fordzlla
trickle charger
I just scrapped an old scanner that stopped working on me .
The power adapter got me thinking. It's one of those little black boxes that plug into the wall and give DC current. It's marked as 15VDC 1A output. I'n thinking that this may be the perfect thing for slow charging a battery, as I have several in storage for the winter, and set on a timer for maybe 1 hour a day may be the ticket to keep these up.
Anybody know if 15 volts is too much for a battery? I know that most auto systems put out around 14volts.
Old Dec 11, 2002 | 01:26 PM
Buckarcher's Avatar
Buckarcher
trickle charger
I would think that 15 volts would be fine. If you look on the voltmeter on the dash I think they don't go red and show abnormally high voltage until 18 volts. That should leave you plenty of wiggle room, (20%)
Old Dec 11, 2002 | 01:37 PM
sideout2's Avatar
sideout2
trickle charger
I wonder if 1A will do anyting? Just my thoughts. I have a bunch of those things. If it worked I could use it on my boat for the winter.
Old Dec 12, 2002 | 12:46 AM
Torque1st's Avatar
Torque1st
Posting Legend
trickle charger
Go to Radio Shack and get a #271-132 (pkg/2) 10ohm 10watt resistor and connect the + lead thru a 10ohm resistor to the + post. You can leave it on the battery continuously if you want then. Change it over to another battery every couple of days or so. Or put it on a different battery one day per week. It does not take a lot of time, and the power pack will not draw much current on a fully charged battery.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Dec 23, 2002 | 06:02 PM
insainity's Avatar
insainity
trickle charger
Oh ive got cold chills thinking about it.But dont pay me any attion im just gun shy.I had a battiery charger blow one up a few feet away one time.The cable end must have arced dureing a power cycle dureing heavy charge.Warning boiling batteries fumes and sparks dont mix they go boom.
So be careful!!!
Old Dec 23, 2002 | 06:24 PM
bjr23's Avatar
bjr23
trickle charger
Sounds okay and I'm thinking about what you said with getting a 10 ohm, 10 watt resistor and would you just kinda go over the calcs. on how this works. I kinda did that and I'm confused it looks like you only get 10 volts with the resistor in there. I always welcome learning new things. bjr23
Old Dec 23, 2002 | 08:46 PM
Torque1st's Avatar
Torque1st
Posting Legend
trickle charger
The calculations for battery float chargers can get kind of complicted due to the charge characteristics of a lead acid battery. My experience with other small current battery charger designs and the availability of parts is why I listed that resistor value. The charger design for a given battery varies with battery construction, capacity, and type of charger. The battery manufacturer usually specifies the type of charger required.
Here we are building a "homebrew" :-) The resistor limits the initial charge current to something the powers supply can handle. It also limits the float current to the battery.
Old Dec 24, 2002 | 06:18 AM
Talltruck's Avatar
Talltruck
trickle charger
pdqford
Electrical Systems/Wiring
17
Apr 7, 2015 04:20 PM
jon705
Apr 14, 2013 10:21 AM
molder169
Sep 19, 2012 07:32 PM
MC333
Jun 27, 2012 04:31 PM
mbarrad
Texas Chapter
Mar 4, 2012 09:51 AM
