360/390 heads?
Old May 17, 2001 | 06:15 PM
6t6merc's Avatar
6t6merc
360/390 heads?
Old Jun 11, 2001 | 06:42 AM
jdbanks's Avatar
jdbanks
360/390 heads?
I bout 72 Ford with 360 in it that either had a bad head gasket or cracked head. Turned out the heads were cracked. So my Dad took them to get them fixed for me, since I couldn't do it at the time. Anyway, we had an old 390 sitting in our shop so he took the heads off of it into the shop too and told them to fix the best of the 4. From what I understand the valves are different in the heads, is there any other differences? And if the guy fixed one of the 360 heads and one of the 390 heads and they are mismatched on the truck would that cause me any problems? Sorry if this is a stupid question.
*jdbanks*
Old Jun 11, 2001 | 01:26 PM
75fef100xlt's Avatar
75fef100xlt
360/390 heads?
You should keep the best pair and not mis-match.
You might end up with an emissions head on one side with a non emissions head on the otherside. This will make an engine run better on one side. That will lead to a poorley running engine. Emmissions heads have filled in exhaust ports which reduce flow.
All Fe heads have the same size valves except for 428 cj's and 427's.
What are the casting #'s on the heads?
Old Jun 11, 2001 | 03:30 PM
jdbanks's Avatar
jdbanks
360/390 heads?
I'll have to get back to you with the casting numbers. Unfortunately I put the heads on a good while back. Didn't even think about checking to make sure they were matched, just took that for granted. But I do have the left over two that I can look over. So if I follow right I can just measure the exhaust ports and see if they match up? If they do then i'm ok, if not then I got problems? There any other differences in the heads? As far as I know one came from the 72 and the other was from a mid 70's, say around a 76 i believe. Thanks for the help.
*jdbanks*
Old Jun 11, 2001 | 05:01 PM
FE427TP's Avatar
FE427TP
360/390 heads?
72 and 76 are probably either C8AE-H or D2TE-AA heads, these two heads are essentially the same, I saw no obvious difference between them when I still had both sets. And as far as I've heard the only difference was the exhaust seats on D2TE-AA were induction hardened to be partially compatible with unleaded fuel.
Old Jun 11, 2001 | 10:06 PM
75fef100xlt
360/390 heads?
[font size="1" color="#FF0000"]LAST EDITED ON 11-Jun-01 AT 11:08 PM (EST)[/font][p]
6t6merc
Jul 27, 2003 07:27 AM
Ratsmoker
Nov 28, 2002 01:42 AM
6t6merc
May 16, 2002 04:19 AM
6t6merc
19
Feb 15, 2002 01:01 PM
