Bronco II Ford Bronco II
Tachometer and Temperature gage
Old Feb 8, 2006 | 04:24 PM
mtmcalli's Avatar
mtmcalli
My tachometer and Temperature gage isnt working right now. My speedo and gas gage and everything works, the only thing thats not functioning is the tachometer and the temperature gage. I have looked at the fuses and none of them are blown. Only thing i can think of is maybe a bad thermostat or a bad ground. But i figured the entire gage cluster was on the same circuit which is why i couldnt understand that the speedo worked and not the tach. Thanks in advance
Old Feb 8, 2006 | 07:57 PM
Ken00's Avatar
Ken00
My book shows all of the gauges are powered by the same fuse so I would suspect a problem with the cluster.
Old Feb 8, 2006 | 08:18 PM
mtmcalli's Avatar
mtmcalli
yeah thats what i was thinking. But if i was to get a new cluster then the mileage wouldnt match up. Is there anything i can do about that?
Old Feb 10, 2006 | 08:48 PM
Ken00's Avatar
Ken00
I'm sure someone will have a better idea but documenting the mileage on the replacement when it's install and the actual mileage.
Old Feb 11, 2006 | 12:31 AM
mtmcalli's Avatar
mtmcalli
i wonder if i could manually turn the dial with my finger until its on my current mileage?
Old Feb 11, 2006 | 02:35 PM
Monty06's Avatar
Monty06
hey mtmcalli good luck took me 3 months to roll back the dial on my mileage to 0 since i got a completely rebuilt engine with 0 miles.
Old Feb 11, 2006 | 06:41 PM
mtmcalli's Avatar
mtmcalli
ehhh what took 3 months? How did you roll it back
Old Feb 13, 2006 | 02:44 PM
Monty06's Avatar
Monty06
to roll back the dial by hand
Old Feb 13, 2006 | 03:59 PM
mtmcalli's Avatar
mtmcalli
you lost me man, i'm not understanding how rolling the dial back by hand would take 3 months. Can you not just turn the numbers with your finger?
Old Feb 17, 2006 | 10:16 AM
AlfredB1979's Avatar
AlfredB1979
If things are like the early 90 Ranger clones, you could swap speedo sections....Mine worked like a charm.
Old Feb 17, 2006 | 11:02 AM
kernel-panic's Avatar
kernel-panic
I would have to agree with AlfredB1979. Get a -working- replacement cluster (or check your wiring connector on the one in place as well as the cluster itself and sending units) and at worst case scenario if it is the cluster, just swap the speedometers. I did that very thing on my '86 Ranger when I went from gage / idiot light setup to the 4-gage setup. I ended up going with a Sun mini tach instead of using a 'stock' tach and adding oil pressure and ammeter / volt gages. *shrug*
Old Primer Red
Jul 25, 2016 07:59 PM
460 1997
21
Jan 22, 2016 10:08 AM
CheckEngine
1983 - 2012 Ranger & B-Series
Oct 1, 2015 07:04 PM
CNC
Jun 18, 2015 06:33 PM
DET.CAVEMAN
Feb 5, 2014 01:06 PM
