Gage cluster
Old Jan 5, 2016 | 08:20 PM
460 1997's Avatar
460 1997
Gage cluster
Hello is it possible to swap my gauge cluster.for on that has a tachometer? Mine didn't have one and I found a nice unit with one..how would I wire it up? I would like to have a tachometer set up.for my 1997 f-350 with the 460... would it to hard to switch them out and hook up.the tachometer?
Thanks
Old Jan 5, 2016 | 10:53 PM
mrollings53's Avatar
mrollings53
Year to year is plug and play. Mixing years requires wiring changes at the wiring harness. '96-'97 gas clusters should work fine in your truck.
Old Jan 6, 2016 | 05:09 AM
Ron94150's Avatar
Ron94150
Watch eBay. I just won one with a tach for less than 30 delivered. It had a busted plastic cover. I will simply use my old cover. As rollings said, watch your year models. I believe they can all be made to interchange with some wiring changes if you know what you are doing, I don't, so mine was the same year, plug and play.
Old Jan 6, 2016 | 12:07 PM
fordf350man's Avatar
fordf350man
I feel like I overpaid... I ended up paying $90 for a clean one off fleabay. If I saw the one you got for $30 I would have snatched it up so quick. I just could not find one cheap (unlike you!) and have been looking on and off for 6 months now. Even called around to some local junkyards a few months ago here in Dallas in an attempt to find one.
From my understanding 92-93 are the same, 94-95, and 96-97. If you do use say a 92-93 in a 94-95 year range I read on here one guy had an issue with battery charging since the battery gauge on his was slightly different and not allowing alternator to charge the battery. Hence why I paid extra to get the right year range. Which I have yet to install.
Hope this helps...
Old Jan 6, 2016 | 01:51 PM
Ron94150's Avatar
Ron94150
Look for the ones with best offer. Mine was listed for 49.99. I just put in a low offer and he accepted.
Old Jan 6, 2016 | 02:06 PM
460 1997's Avatar
460 1997
I just found one on eBay for a 96 f-250 but it's for a diesel...does that make a difference?
Old Jan 6, 2016 | 02:07 PM
fordf350man
Yes you need a gas one. Diesels were different clusters.
Most on eBay will say gas or diesel in the title for that reason.
Old Jan 6, 2016 | 02:09 PM
460 1997's Avatar
460 1997
Ok thank you...appreciate the help
Old Jan 6, 2016 | 03:12 PM
460 1997's Avatar
460 1997
Boy they sure are proud of the ones with tachs. 119.00. Wow
Old Jan 6, 2016 | 04:26 PM
frank5079's Avatar
frank5079
I have a cluster with tach that I bought for my '95 truck, but I really wanted the 120mph Lightning cluster which I found later, so I have no use for the cluster. If you think you can make it work, I'll let you have it for $50.00
Frank
Old Jan 6, 2016 | 04:53 PM
fordf350man
Frank
If he does not buy to adapt for his 1997 Ill buy it off you! PM me.
Old Jan 6, 2016 | 04:59 PM
Fastback460's Avatar
Fastback460
I have one from a 92 sitting in the garage. But I have yet to find one for my 97.
Old Jan 6, 2016 | 05:01 PM
fordf350man
Heck if your looking to sell too let me know. I could use one for my bronco if the price is right.
Old Jan 6, 2016 | 05:29 PM
460 1997's Avatar
460 1997
I am not that good with electronics and wiring ...but thanks anyway
Old Jan 6, 2016 | 05:31 PM
460 1997's Avatar
460 1997
Would love it but not that good with wireing and electronics but thanks anyway..I appreciate it
