Locking Hood Latch/Cable
Old May 1, 2001 | 05:35 PM
stephenw's Avatar
stephenw
I have parts coming from various sources to retrofit my '74 with the locking hood latch and cable setup. However, having never seen the installation, I am wondering how the cable "T" handle and cable were factory-mounted and -routed to the latch?!? I'm sure that at least one of you has this important security item on your truck to look over and give some insights? ;-)
Thanks, Steve
Old May 2, 2001 | 09:39 AM
karljay's Avatar
karljay
The handle mounts under the dash left of the steering wheel at the bottom of the dash. the cable goes thru the firewall to the left of the rad to the front of the truck. The cable ends inside a box that has the pull lever in it and the box is held on by 1 screw and makes it so that the cable can't be pulled from the outside.
The handles are either locking or non-locking, the non-locking is plastic and the locking is metal.
Hope this helps.
Old May 2, 2001 | 10:35 AM
laptopgeek's Avatar
laptopgeek
Steve ----
Pleez oh PLEEZ tell me where your ~locking~ cable kit came from. I would feel so much better if I could lock my '74 up, too. He's an F100; name is Harrison. Good luck with your install job - I bet it'll be swift.
Need a company name & number, if you would, please - I'll order it tonite...
Old May 2, 2001 | 12:44 PM
stephenw's Avatar
stephenw
Thanks KJ! That's kind of what I figured, but wanted to be sure before removing a piece of firewall! Did they do any special routing along the side of the fender liner?
Laptopgeek, hope you are sitting down when you look these up. Outrageously expensive, but just don't seem to find parts trucks laying around in my part of the country. They're all still on the road, being Fords and all! I found that www.ford-obsolete-parts.com has both the latch and the cable assembly, look up E7UZ-16700-A $71.95 (latch) and D5DZ-16914-A $148.95 (cable) and D8TZ-16978-A $23.95 (cylinder). LMC Truck at 1-800-222-5664 has the locking cable only: 40-3870 $129.95, and lock cylinder 47-0689 $24.95, and their shipping rates are monstrous. And finally, Recks and Relics at ww4.choice.net/~truck had the latch for $65, no cable. And Dennis Carpenter had neither! So, get out your check-book, and good luck!
Old May 2, 2001 | 12:48 PM
laptopgeek's Avatar
laptopgeek
Ack!!! I think I'll just tie up old Moe (my 240 pound Rotweiller) to the front bumper!! Jeez....I knew Fords were great, but they CHARGE for it to!..Thanks for the info --I'll print this and maybe next year I can buy it.
Regards..
The LapTop Geek (in the slow lane, till the 460 gets shoe-horned in)
Old May 3, 2001 | 01:12 PM
karljay's Avatar
karljay
This guy found one from AudioVox, it looks good but I've never been able to find it on AudioVox's web site. It's a locking type and probably stops at the cable, so you'd still have to find/make the latch part.
http://members.home.net/mattjibb/truck1.html
He's just got the picture, no part numbers.
Old May 3, 2001 | 03:47 PM
swamp master's Avatar
swamp master
The lock that is shown appears not to be hood latch, but an electric bypass to prevent theft. It says it wires to the starter.
Old Jun 15, 2001 | 10:47 AM
rompen78's Avatar
rompen78
I have just put that lock in made by AudioVOX. I bought it from JCWhitney. Runs about 40 bucks, took me about 2 hours to put in! Works great. I don't remember the part number, but it mentions hood lock for cars, trucks and vans. Hope this helps!
Rompen 78'
Old Jun 15, 2001 | 11:17 AM
loudfords's Avatar
loudfords
pwstroker69
Mar 17, 2015 08:37 AM
hhight
WTB - Parts & other
Nov 8, 2014 07:13 AM
senix
Oct 23, 2014 05:02 AM
Wayne Waldrep
21
Aug 3, 2014 05:25 PM
droppedf100
Feb 9, 2008 12:43 PM
