Sponsored by: Kumho
Shaking and Breaking pluse grinding
Old Feb 7, 2006 | 08:11 PM
zemus420's Avatar
zemus420
Ok guys, I need your help on a few things. First of all I have NEW rotors and brake pads (by new i mean less then 6 months old) I changed them due too shaking while breaking and grinding well needless to say that didnt help the problem very much still does the same damn thing. No i did not replace the wheel bearings due to unavailibility. Where should I start looking now? Brake Clipers? Rear Drums? what?
Old Feb 8, 2006 | 06:25 AM
tjc transport's Avatar
tjc transport
i ain't rite
if it did it again as soon as you put the new rotors on, i would check the front suspension components closely. tie rod ends, pitman arm, steering box, wheel bearings, shocks, and depending on the vehicle, radius arm bushings and spring mount bushings.
Old Feb 8, 2006 | 08:31 AM
Sycostang67's Avatar
Sycostang67
If it slowly came back after replacing the pads and rotors, you may have a sticky caliper that is causing a rotor to get too hot and warp. I replaced my rotors about 8 months ago because they were warped, and they mentioned that one of my calipers seemed sticky. I can start too feel a little vibe when I am breaking now.
Old Feb 8, 2006 | 05:15 PM
zemus420's Avatar
zemus420
Its a 95 F-150 2X4. I think im going to start with New Calipers, Wheel Bearings, Shocks and take a look at the Drums. Ill get started on it this weekend until then keep giving me some ideas. Thanks for the help so far guys really means alot.
Old Feb 9, 2006 | 10:49 AM
73Custom's Avatar
73Custom
Have you inpected the rear brakes recently? The grinding might be back there. Drums can get hot and warp too, also causing a vibration.
Marty
sheaff44
Jan 19, 2015 07:14 PM
11sbrown12391
1997 - 2003 F150
Oct 9, 2012 08:34 PM
dockrocker
Aug 26, 2012 09:43 AM
77f100guy
Mar 18, 2012 07:54 PM
iilijah
1997 - 2003 F150
May 6, 2011 10:01 AM
