vibration
Old Feb 7, 2006 | 12:39 PM
MSC's Avatar
MSC
vibration
I've got a harmonic vibration on my 86 F150 2wd. It happens during deceleration or coasting only. Isn't there one type of problem that causes vibration on acceleration and different type of problem that causes vibration on deceleration. I seem to remember reading something like that? What should I check?
Old Feb 7, 2006 | 01:50 PM
big hoss 29's Avatar
big hoss 29
What kind of shape are your u-joints in? Bad u-joints can cause alot of vibration on acceleration and deceleration, it just depends on how bad they are.
Just crawl under the truck and grab the driveline and try to move it, side to side, up and down and in a turning motion. If it moves, you need new u-joints.
Old Feb 10, 2006 | 08:20 PM
MSC's Avatar
MSC
big, I dropped the drive shaft tonight. The front joint was bad, rusty and pretty beat up in one of the caps. Changed both joints while I was at it. Thanks.
MSC
mulvaney324
1997 - 2003 F150
Aug 25, 2011 09:04 PM
dyna
Oct 7, 2009 09:53 AM
bhd
Mar 14, 2007 11:12 PM
MALIBUBASS
2004 - 2008 F150
Nov 2, 2004 03:37 PM
