turn signal cam
Old Feb 7, 2006 | 11:47 AM
MikeSmith's Avatar
MikeSmith
turn signal cam
I just had a lousy experience with LMC, and I don't want to order from them anymore. But I still need a turn signal cam for a 66 F100 2WD. Anyone have a favorite source for these sorts of parts, prefereably one with an online catalog?
Old Feb 7, 2006 | 11:59 AM
bertha66's Avatar
bertha66
MAC's or NPD have catalogs, and good paces to get parts.
Old Feb 7, 2006 | 01:33 PM
Ak65F100's Avatar
Ak65F100
hi, you may find cam at napa . Dodge truck 70tomid80 use the same turn signal cam.
Old Feb 8, 2006 | 05:55 AM
jowilker's Avatar
jowilker
Mike, Those cams should be available at any parts house.
John
Old Feb 8, 2006 | 06:26 AM
ddavidv's Avatar
ddavidv
Carolina Classics is my absolute favorite supplier.
And yes, he has a catalog.
Old Feb 8, 2006 | 12:02 PM
MikeSmith's Avatar
MikeSmith
John, I've already gone through two wrong cams from local parts stores. Both of them were supposed to fit but were just slightly different. And then LMC sent one that wasn't even close. I finally just ordered the whole switch. Thanks for all the replies.
Old Feb 9, 2006 | 03:43 AM
jowilker's Avatar
jowilker
Mike, You shouldn't have that kind of trouble, those things are pretty basic and I think were used for several years. If you have one that does fit, take it with you. The last one that I bought was in a clear wrap, you could match it up. IMHO
John
Old Feb 9, 2006 | 07:59 AM
Winterbuoy's Avatar
Winterbuoy
Got mine from Dennis Carpenter for my 65, fit perfect, works perfect. Had A brake light problem and this was the solution. Not cheap but happy
Old Feb 9, 2006 | 11:42 PM
ford390gashog's Avatar
ford390gashog
the parts store ones are pretty sad. they are flimsy junk. shee Mar still makes them to oem specs in their small facilty. give them a try. google shee mar inc
Old Feb 10, 2006 | 06:45 PM
jd_sylvia's Avatar
jd_sylvia
I got mine for my 65 at Vintage Ford in sacramento. Fit good and works, it is nice not to have to turn the thing off every time you use it.
jd
