electrical trouble HELP!!!!!!
Old Feb 10, 2006 | 01:37 AM
HAWKYPUCKS's Avatar
HAWKYPUCKS
ok i have a 1964 ford f-100 i need to wat the clear light under the brake light is and were it runs to. any information willHELP!!!!!
Old Feb 10, 2006 | 05:31 AM
ddavidv's Avatar
ddavidv
That would be your backup light. Optional equipment, or added by a previous owner. You can either remove them and avoid the problem or see if there is a reverse light switch, probably on the steering column around the shift linkage.
Old Feb 10, 2006 | 11:35 AM
bertha66's Avatar
bertha66
I don't think that Ford put back up lights on these trucks untill after 67, so I think that a PO swapped out the solid lens for a set of newer lens. Pull the lens out and see if there is a second light bulb in the housing for the back up light.
Old Feb 10, 2006 | 08:22 PM
Bob P1's Avatar
Bob P1
Is this a stepside bed? If so, and it's only on the left side it is the license plate light.
