86 trouble starting
Old Feb 7, 2006 | 11:25 AM
73-79owner's Avatar
73-79owner
86 trouble starting
Have a 86 150 that will not start. The key turns but will not make the truck start. You can use a screw driver and jump from the solinoid to the battery and make it start. I have replaced the starter solinoid on wheel well, ignition switch on column, and key switch on column. Also the neutral switch has been replaced. Anyone ever had this problem and if so what was wrong.
Old Feb 7, 2006 | 11:32 AM
tsheriff's Avatar
tsheriff
Is this an EFI or carb. truck. What size engine?
Old Feb 7, 2006 | 02:30 PM
Gregorri's Avatar
Gregorri
I had a similar problem on my dads 1969 F-250. Turned out to be a bad ground. I took off the soleniod, and cleaned the metal behind it with steel wool.
Starts every time now.
Hope this helps,
Rick
Old Feb 7, 2006 | 04:59 PM
redwood's Avatar
redwood
I'm with Gregorri. I'd look for corroded and broken wires, blown fuses, bad connections, etc.
Old Feb 7, 2006 | 10:02 PM
73-79owner's Avatar
73-79owner
86 not starting
it is a 351 Windsor with a carb
Old Feb 7, 2006 | 10:43 PM
Larry_the_handyman's Avatar
Larry_the_handyman
Gregorri got it right, you've got a bad wire somewhere between the key and the solenoid. Try bypassing each one with a test lead.
Old Feb 9, 2006 | 02:17 PM
Brothers 4x4's Avatar
Brothers 4x4
Don't forget about the ignition actuator. Does the key do anything when you turn it (cranking etc.), or is it just dead? If the ignition actuator inside the column is broken the key will turn but nothing will happen; NOTHING. But, if the truck cranks it wouldn't be related to the ignition actuator. The actuator is connected to a metal rod that runs down the top of the steering column and trips the ignition switch (also located on the top and bottom of the steering column. (The ignition switch is controlled by the position of the key) When the actuator (a small cresent shaped piece of cast aluminum) breaks, the ignition switch gets stuck in whatever position it was in when it breaks. The first time I broke one, the truck was running and it took me a while to figure out what the heck was going on. The part is only about 9 bucks. However, the labor on it is about 150 bucks. You can do it yourself, but there are a lot of tricky things to watch for when disassembling a steering wheel and column. But hey, if I can do it anyone can. Hope this is some help to you, if not thanks for listening anyway.
Old Feb 9, 2006 | 10:25 PM
Bdox's Avatar
Bdox
Also check fusable links!!!!
McKenny
Oct 15, 2011 11:19 AM
heartnurse73
Oct 22, 2009 07:46 PM
oobical
Jun 12, 2008 10:49 PM
RyanGruhn
1978 - 1996 Big Bronco
Apr 11, 2003 01:26 PM
vern
Feb 13, 2001 03:06 PM
