Pyro Install
Old Feb 7, 2006 | 09:24 PM
marvinlong's Avatar
marvinlong
i used a cordless going pretty slow and had no problems. wish i had a tap handle but instead used a 12pt. socket. worked ok but squirilly
Old Feb 7, 2006 | 09:29 PM
hink10's Avatar
hink10
I used a step drill bit for the hole, worked very good and didn't have to change bits. I used a magnet too and then sucked out with shop vac.
Old Feb 7, 2006 | 09:30 PM
Muktown's Avatar
Muktown
yes be sure to get your tap started straight and check your thread depth because pipe thread is a tapered thread that actually seals on the thread. that is why the sensor will not bottom out into your exhaust manifold
Old Feb 7, 2006 | 09:32 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
when i was finished drilling and tapping my manifold, i took my shop vac and sealed the area around it and sucked out all the shavings. when i was done, i took the top off and looked in the cart of dust and dirt out of curiousity, and it had a fine layer of soot on the top. along with the shavings, it sucked some of the carbon out too.
Old Feb 7, 2006 | 10:06 PM
rmilchman's Avatar
rmilchman
If it's tapered how do you know when to stop cutting the thread? Keep measuring until you just get the depth of the pipe?
Old Feb 8, 2006 | 06:56 AM
missouguy's Avatar
missouguy
I did dip the bit in light bearing grease and all the shavings pretty well stuck to it. Used about 3 bits working up. But then I am paraniod. No sweat.
Frank
Old Feb 8, 2006 | 06:58 AM
Kwikkordead's Avatar
Kwikkordead
Yes. The best way is to remove the tap after cutting in a few turns and experimentally thread the fitting into the manifold. It needs to start to feel snug at about three turns in. It will be nice and tight by the time you get to the shoulder.
Old Feb 8, 2006 | 08:03 AM
Hotwheelbill's Avatar
Hotwheelbill
Frank
Good idea! It should keep some shavings out of your face too!
Old Feb 8, 2006 | 09:13 AM
hink10's Avatar
hink10
Frank
If you use grease, be careful not to get any excess grease in the pipe or the shavings might get stuck in the pipe rather than to the bit.
Old Feb 8, 2006 | 06:30 PM
Muktown's Avatar
Muktown
you want the probe tip about the center of your exhaust flow. the nut on your pyro will not be touching the manifold and you will see a couple of threads. i think mine is about three quarters up the the threads with the other quarter sticking out of the manifold
Old Feb 8, 2006 | 06:33 PM
Muktown's Avatar
Muktown
i agree i just drilled mine dry and straight up so all the shavings fell down and then i stuck a telescoping magnet into the pipe and got the rest of them then i took a shop vac to the hole. i know its a little paranoid and the shavings that are left will just blow right by the turbo but i diddnt want to take a chance
