'Clunk' at start-up
Old Feb 7, 2006 | 06:26 AM
dlpinkc's Avatar
dlpinkc
'Clunk' at start-up
My truck had been sitting for 3 days when I went to start it yesterday. It was about 25 degrees out, and block heater wasn't plugged in. Waited for the glowplug light to go off and it started right up. Immediately after starting, there was a 'clunk'. One clunk only. It 'seemed' to come from the passenger side of the engine, but I wouldn't swear to that.
First time I ever heard it. Not particularly worried about it either, just wondering if this had ever happened to anyone else.
btw - 2005 with a little over 11k miles. Zero issues so far.
dlp
Old Feb 7, 2006 | 06:57 AM
Maxium4x4's Avatar
Maxium4x4
Could be you heard your blend door in your heater close shut.
Old Feb 7, 2006 | 08:07 AM
Rangercd's Avatar
Rangercd
clunk
Could it have been the air conditioning compressor clunking? Besides my 6.0 which I have not heard a clunk yet, I have a v10 that has a clunk almost every time I start it. Scared the devil out of me the first time it did it. I thought something (cat) got into the belt. I was able to track it down to the compressor clutch engaging.
Old Feb 7, 2006 | 03:16 PM
AlaskaPowerStroke's Avatar
AlaskaPowerStroke
I agree with Maxium 4x4, about the door in the heater. Sometimes I hear it, sometimes I don't, and it has been at different temperatures. But, definitely try to find the source so you know for sure what it is that is making the clunk.
Old Feb 7, 2006 | 04:12 PM
019945's Avatar
019945
'Clunkfrom engine compartment at start up
I have this same concern, and I have no idea what it is, so anyone that might now- please give your input...With all of the EGR Valve problems in these 6.0's I was thinking that maybe it was my EGR Valve coming open/ closed from being stuck, and that's why it clunked?
Old Feb 7, 2006 | 04:17 PM
Custom Plumber's Avatar
Custom Plumber
It`s not the EGR valve clunking, It`s the door / flapper located in the HVAC duct that you here. I have 2 e350`s and 1 F250 that do this same thing and yes, it can scare the crap out of ya the first time
Old Feb 7, 2006 | 04:18 PM
Maxium4x4's Avatar
Maxium4x4
You'll never hear the EGR valve opening or closing. When you key the truck you will hear the fuel pump, vacuum pump and depending on the position of your climate controls, heater switch, the blend door will "Clunk" when it returns to position.
Old Feb 7, 2006 | 04:24 PM
019945's Avatar
019945
Thanks Maximum4X4 and Custom Plumber...I thought that it could maybe be the HVAC door too... But it sounds like it is becomming "un-stuck" or something, since it is such a loud clunk. You think it's normal to be so loud? Can this door ever become stuck, or "sticky"?
Old Feb 7, 2006 | 07:23 PM
usroute66's Avatar
usroute66
I always shut off the heater/ac before shutting down the truck. That keeps the compressor from "clunking" on at startup. I noticed the same and that took care of that problem.
Old Feb 8, 2006 | 06:12 AM
dlpinkc's Avatar
dlpinkc
Thanks to all. I haven't yet heard it again. If/when I do I will at least have some ideas what I might be listening for.
Old Feb 8, 2006 | 08:08 AM
GarageDoc's Avatar
GarageDoc
I agree with Maxium4x4, I have always had the clunk and was able to isolate it to the blend door.
Old Feb 8, 2006 | 10:02 AM
roozter's Avatar
roozter
I do the same thing. No clunky, unless I forget then my wife goes "What was that?!"
Old Feb 8, 2006 | 10:17 PM
SD luvr's Avatar
SD luvr
Rest assured, it's the blend door closing. My 04 F250 does it, and so does the 03 Ford Crown Victoria I drive at work. Nothing to worry about.
Ryan50hrl
2004 - 2008 F150
20
Jul 22, 2016 08:18 PM
superseal
Jun 9, 2014 10:14 AM
gd98tj
Escape & Escape Hybrid
Dec 9, 2006 12:11 AM
SOONER4EVER
Jun 13, 2006 04:07 PM
matthewtjones
Dec 6, 2005 01:54 PM
