Turbo whine question
Old Feb 5, 2006 | 06:40 PM
yukonsly's Avatar
yukonsly
Should the whine be one consistent whistle....mine sounds more like......wooohhhhooooohhhhoooohoooosss instead of woooooohhhhhhhhhhhsssss.....Didn't know how else to make the sound....does anyone have a clip so I can hear what a regular sound is.....never noticed before....but curious.
Yukonsly
Old Feb 5, 2006 | 06:42 PM
yukonsly's Avatar
yukonsly
Sorry....forgot to mention....doesn't look like I have any power loss. Everything else seems ok.....and....would very cold air temperature affect it....it's -15F today
Yukonsly
Old Feb 5, 2006 | 07:18 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
That's cold. Wouldn't surprise me if that had something to do with whatever it is you are trying to describe. Especially if it is something it doesn't normally do.
Old Feb 5, 2006 | 07:28 PM
fridgeddiesel's Avatar
fridgeddiesel
When the truck is cold, the EBPV (exhaust back pressure valve) kicks in to warm up the engine/cab. You can really hear it with a 3" down pipe and 4" exhaust, no cat. When you step on it, it will cut out for a moment and when the load goes off the engine it will come back until the engine is warmed up. You will also notice what feels like a loss of power or a hesitation. If you have a turbo pressure gauge, it will read zero when the valve is closed. This could be the different sound you hear in the turbo when it is cold. It is louder than the normal turbo wine and intermittent. See if it goes away after the truck is warmed up or if it disappears for a bit when you load the motor. Hope this helps...
yukonsly
Alberta Chapter
Feb 10, 2010 05:39 PM
yukonsly
20
May 30, 2008 05:29 PM
yukonsly
45
May 30, 2007 11:32 PM
yukonsly
May 16, 2007 04:09 PM
yukonsly
Apr 19, 2007 07:22 PM
