I have one. I have the whole cluster from the 95 I am parting out. Also might be worth giving these guys a call to have it repaired. Electronic Speedometer Service
He's been having trouble with the speedo bouncing.
Nice one Rog, but Jim is right. It's the little computer behind the speedo that takes the signal from the VSS on the rear end, runs the speedo, and sends the info on to the PCM.
Have you checked the wrecking yards? You could buy a cluster from any 92-97 and just swap the good PSOM for the bad one if you can't find another 95 cluster.
Just so you know I put one out a of a 93 f150 in my 96 and it worked great. Hopefully soon it will be working great in RÖENTGEEP's truck. It was in kmh but I dont think that will make any difference. I belive the only differance is in the volt meters and the brake was from 93-94 but im not 100% sure on that one. Good luck.
Just get a cluster out of the right year truck so all your indicator lights will work properly. Or like I said earlier, if you can't find one just pull the clusters apart and put the PSOM into your cluster. I wouldn't drive it much more until you can fix it or you could fry your trans for good.
