Expedition Codes
Old Feb 4, 2006 | 08:25 PM
pigfarmerdk1's Avatar
pigfarmerdk1
Question Expedition Codes
Had codes p1151 &p0153, Changed out the o2 on the drivers side before cat now I have code p0155 & p1151. Any one have any info on where to go next. I got a 97 5.4 Expo. The o2 I took out was a ford bosch part. put in a bosch sencer. Plus I can;t get the interier lights off when a door opens. Thanks dave
Old Feb 4, 2006 | 08:27 PM
Beast12's Avatar
Beast12
Welcome to FordTrucks.com! We are the Internet's Premiere Resource for all things Ford Truck and SUV related!
We are happy to have you! There is a ton of great info on this site. But, before you go snooping around there are a few things you need to do first.
1) Want to meet or talk to other members in your area? There are Provincial, State and International Chapters located near the bottom of the main forum page.
2) Before you post a thread asking a question be especially aware of where (what forum) to place it in. FTE is HUGE! Make sure you read the Read First: at the top of the forum before you go posting.
3) And finally you should review the Guidelines. They will kind of give you an idea of what is and isn't allowed on this site ("The Rules").
And that is it. I hope you enjoy the FTE "Experience"! This is a great place and we have lots of fun while exchanging valuable info. If you have any questions or problems do NOT hesitate to contact me. Just click my username then send me an email.
-Matt
P.S. Thread moved to the Expedition forum.
Old Feb 4, 2006 | 08:58 PM
01silvergt's Avatar
01silvergt
P0153 Heated O2 Sensor Circuit Slow Response (Bank 2, Sensor 1)
P0155 Heated O2 Sensor Heater Circuit Malfunction (Bank 2, Sensor 1)
P1151 Lack Of HO2S21 Switch - Sensor Indicates Lean
Its not uncommon to get a "bad" new O2 sensor. Might want to try to replace it again. Make sure you are using the correct Bosch sensor and not a Universal Basch sensor or one for the rear. You couls also have loose wires either on the connector or on the term strip where all the O2 sensor wires connect. Might have to trace the wires and see, assuming a replacement sensor still gives you the codes. The 1151 code is a tricky code to diagnose. Some people get the code, when they have fuel related issues, others with exhaust issues. Since you also have the O2 code, I would lean toward that being the problema dn giving you the 1151, but I could be wrong. Try another new sensor first.
jamesjone
1997 - 2003 F150
Dec 1, 2014 07:41 PM
NJ_98Navigator
Jun 5, 2011 11:40 AM
MEMO847
Jan 16, 2006 02:56 PM
alan911sc
Jul 20, 2005 05:53 AM
Ultramagdan
1997 - 2003 F150
Jul 15, 2002 06:55 PM
