axle code...183?
Old Feb 3, 2006 | 10:12 PM
hatyswim's Avatar
hatyswim
axle code...183?
hi everyone... the stamp on the door reads 183... does this mean 18 3 speed?
Old Feb 3, 2006 | 11:05 PM
tdford's Avatar
tdford
I'm only going to be able to answer half your question. If you are reading the right line the 18 would be the ford 3.08.
Don
Old Feb 4, 2006 | 07:10 AM
Dungeon_Master's Avatar
Dungeon_Master
I think its a mis typo 18 is axel code and the 3 maybe the tape code. if so here is what I have.
Axle code:
F-150/250/350 non limited slip:
Code...Man...Size...GVW..Gear Ratio
18......Ford....8.8"...3750...3.08
Old Feb 4, 2006 | 12:26 PM
hatyswim's Avatar
hatyswim
thanks everyone... I was suprised when I saw the 183 so i figured a typo on the sticker... but just wanted to check
Old Feb 16, 2023 | 10:36 AM
SB86F150's Avatar
SB86F150
7th Gear
I realize how ancient this thread is, but there didn't seem to be a logical conclusion re: code 183. The info regarding 18 makes sense, 8.8 w/ 3.08 but my label also states 183 (1986 F150, 300, TOD 4 sp OD, 8.8 rear end). Was it common for Ford to have a typo on a vehicle label and replicate that mistake for tens of thousands of vehicles? If anyone is still around, could you elaborate on the definition of "tape code." Thanks.
Old Feb 16, 2023 | 10:47 AM
SB86F150's Avatar
SB86F150
7th Gear
Nevermind, I see that Tape Code is the next box on the manufacturers label. It appears to me that Ford's intention was 183 in the Axle Code.
Old Feb 16, 2023 | 05:13 PM
Franklin2's Avatar
Franklin2
But there was no 183 axle code. There were no 3 digit axle codes.
Old Feb 16, 2023 | 08:46 PM
85e150's Avatar
85e150
I know it's old but this seems to be consistent going back to the late '50s"
183
18 = rear axle code, in this case Ford 3.00 or 3.08, 3750 lbs/non locking, or 3800 lbs/locking or non-locking, depending on year.
3 = front axle code, in this case "power steering delete".
Old Feb 17, 2023 | 12:12 AM
SB86F150's Avatar
SB86F150
7th Gear
That explains it. It was empirical that on the door jamb Manufacturers Label, in the box labeled Axle Code, that my truck (and many others on this thread) was 183. It's not a typo. And even though we know Axle Codes are two characters, this clearly has 3 characters. Thanks for the cipher and the deep Ford knowledge. Much appreciated.
Old Feb 17, 2023 | 07:07 PM
Franklin2's Avatar
Franklin2
I am glad you are satisfied. I don't get how the power steering delete code could be in the rear axle ratio box, but we will go with it. Do you guys with the "3" all have manual steering?
Old Feb 17, 2023 | 07:52 PM
85e150's Avatar
85e150
The axle code is "always" broken down by 2 digits for the rear, the 3rd for the front. In some years there is no front code when it is a standard axle.
Some of the codes have alternate meaning, usually made "clear" by the wording and date ranges etc.
Old Feb 18, 2023 | 06:36 AM
Rembrant's Avatar
Rembrant
I know the Ford literature says that the 3 is for power steering delete, but people have shown up various times over the years with a "183" axle code, and the trucks always have power steering. One of the old Ford dealer guys...maybe it was Bill/Numberdummy said that the 183 code was a mistake, and that there never was a power steering delete code on these trucks. However, they do show up every now and then with that code.
I know there were trucks earlier on (all 2wd) with manual steering, but it was never indicated on the Certification label.
Old Feb 18, 2023 | 06:57 PM
85e150's Avatar
85e150
Scroll down to page 43 or so for the front axle codes:
https://www.forelpublishing.com/demo/Demo20083.pdf
Old Feb 19, 2023 | 09:38 AM
SB86F150's Avatar
SB86F150
7th Gear
Great documentation. Thanks for posting.
1972fordhighboy2
Aug 27, 2017 11:29 AM
andypinto
Nov 30, 2007 05:50 PM
jc's82f150
Apr 17, 2006 08:42 PM
Mark76f250
21
Feb 21, 2004 04:18 PM
kaisermat
Mar 3, 2002 12:37 PM
